1.9 tdi bxe replaced with bkc
Recommended Posts
hi all
unfortunately a few months ago my bxe decided to fail (hole in block)
i sourced a bkc engine complete with pump and injectors, from a 2006 vw jetta and got it fitted
I have noticed that my mpg is down now to about 42 where it was previously over 50
there is no faults stored on the car
i am just wondering if this is something that a software update in a main dealership would help
or has anyone any other ideas.
i have changed the fuel filter
checked heater plugs and loom
changed air filter
the egr was cleaned at the time of the engine replacement.
would a software update affect the injectors
thanks in advance
Link to comment
Share on other sites
I think these engines are very similar, the injectors and ancilliaries appear the same from what i have read so the maps 'should' be the same.
Do you have access to VCDS to check the timing? Also would be worth logging a few things to see if there aren't any obvious problems
Edited by SuperbTWM
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
