Retro fitting heated seats - where do these go
Recommended Posts
I'm fitting everything I need to wire in heated seats... Got the proper loom etc
I've got everything plugged in ready so the seats are all sorted, plugs and switches all good but I'm left with these...
The wire that's on its on I'm at a loss... They come with zero instructions so not a clue.
I'm guessing the one with the hole connection is going to be bolted down as an earth?
Link to comment
Share on other sites
Never noticed the writing on them, the guides I checked all had coloured cables.
From what I've worked out...
Top - main live to fuse box
Next - lighting for switches
Next - control module
Next - earth
Next - live for other pin in fuse box
  • Like 1
Link to comment
Well got the Control modul down (i think)
But not sure which pins they go in
Also it's just a maze of wires, going to test them all tomorrow to see if I can get a switched live so it only works when the ignition is on so the seats will still switch off when I take the key out.
Link to comment
so you have the same things also?
I've done some coding before for things like the alarm chirp, indicators flashing, auto closure etc but when i look at that im just confused...
what does "
  • +00032 = Heated Front Seats installed"
even mean!
Yeah, its a poor excuse for a guide really since i need guiding :D just taking pictures as i go for future reference and so others can see how its done.
Link to comment
what does "
even mean!
Just add that number to your existing code then recode the result.
  • Like 1
Link to comment
any suggestions for the main live feed?
i can see a few lives (thick red wires) but idealy it will be from a switched live, im worried wiring the heated seats into a random switched live might be to heavy for whichever wire and cause a fire possibly?
Edited by hutchysrs50
Link to comment
I have Polo 9N leather seats (already have the heated elements in place from the factory) fitted to my Fabia and I have bought some secondhand heated switches.
I just need to purchase the Kufatec loom and wire it in/code it, it is just having the time to do it.
Link to comment
Sounds nice, would be a huge bonus already having the seats fitted with heating elements! sadly it wasnt even an option on the special edition so im douting any special edition is heated out there!
i'll take plenty more pictures and update the guide as i go tomorrow :thumbup:
  • Like 1
Link to comment
all went well wiring them in, I used the switched live from the fans since it's a heavy duty cable that switches off when the ignition is switched off.
The right side of the fuse is the source also.
Took plenty of pictures.
Currently trying to code them in.
Link to comment
This does seem to be the most effort modification ( or retro fitment ) I've heard of perhaps 2nd to only trying to retrofitting the maxidot !
Only because I seem to recall reading loads ot threads about the seats but don't think I've come across a complete finished seat wiring solution thread ?
I guess this is the time to get the benefit from it though, but I never ever seem to feel that cold in my car to feel it warrants the effort this would take to fit to go through all this heartache !
( I've retrofitted cruise myself but this sounds like a bit of a ball ache If I'm honest, I'd need to get the switches and looms and work out the wiring, assuming my Recaro heating seat elements even work and can work out the wiring combinations and......I just can't be bothered ).
Good luck though, any knowledge surronding this would be definitely beneficial to all !
Link to comment
Presumably works a bit like 8 bit binary by sounds of it ?
+32 is the part of the binary "bit" that presumably this seat on off bit ?
e.g.
1 2 4 8 16 32 64
0 0 0 0 0  1  0
so it you currently have 64 + 32 = 96 (which is bit 64 on and 32 on)?
Sounds like....just basic binary
  • Like 1
Link to comment
Thanks, yeah I don't know anybody that's tried this and has then working 100% either. Only one member on here Sam, has done this but he's wired his slightly different.
Hopefully I can be the first 100% successful OEM retrofit as if it left the factory :)
  • Like 1
Link to comment
It's the only wire I havnt plugged in yet, im worries incase it's to much or somthing.
Basically I've got a switched live wire feeding the fans. It's the same gauge wire as the heated seats and also has a 25amp fuse.
If I piggy back from that live am I then doubling the useable and possibly running up to 50amp with the fans and heated seats on through a wire designed for 25 amp?
I'll take a picture now and post it up
Link to comment
That puts my mind at ease a little more, I thought it was 25.
I've wired up the cables to the correct fuse point, 63, but the feed needs to come from somewhere still to feed the fuse.
The link doesn't work for me also.
For now I'm going to take the pin out of the fuse holder for the fans and put it into the heated seats and test them out. Then work out what to do!
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
