Cold start issue
Recommended Posts
Hi guys hoping you can help
My octy vrs has developed a cold start issue where first start, she starts fine then after. Few seconds coughs and splutters and almost conks out. If I give it a little revs the problem clears up almost straight away. I have no codes coming up for it.
Any help appreciates
Link to comment
Share on other sites
interesting!!! I have just developed the same problem, thought it might be something to with the secondary air thing as its been noisey for a bit, and if I start in from cold and leave it for about 30 secs on idle it doesnt seem to do it and drives fine.  Very interested in peoples thoughts this
Link to comment
I had my secondary air pump taken out over a year ago, I've read it could be the cold air sensors behind the throttle body or strangely the rocker cover gasket leaking although I can't see how the later would effect this.
It doesn't seem to do this every time either
Link to comment
  • 4 weeks later...
My mk1 has had the same problem recently, if I pull away before the initial start revs have dropped, I can be kangarooing down the street. Works fine if left to warm up for a minute. Plugs, leads and coils changed. Premium petrol used. All made no difference. Not as bad on warmer mornings. Air intake or sensors perhaps?
Any help/ advice appreciated.
Festa
Link to comment
  • 2 months later...
Just wanted to update the problem. Starting issues got worse, vrs started to rev on its own, lots more kangarooing in all weathers/ temperatures. The orange engine light on dashboard permanently on.
I just replaced mass air flow unit (£25 delivered), job took about 15 minutes, car started 1st time, idles evenly, no kangarooing, no light on dashboard.
Link to comment
Looks like my guess was correct :)
Many people on here have reported issues with cheap MAF sensors, so if you have problems with the new one then I'd recommend replacing it with a genuine Bosch one.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
