Reversing sensor intermittent
Recommended Posts
After the car has been in the garage overnight, the car starts normally but when I select reverse, the system beeps normally and the car symbol on the radio shows but after a couple of seconds, there is a longer, higher pitched beep and the car symbol disappears. The reversing lights work normally but there is no audible or visual reverse sensor warning. Usually, after driving for a few miles, the system starts to work normally until the next time it's left overnight.
Is it possible I have a gremlin in my garage that comes out at night and messes with the car? :D
A wiring diagram of the system would be useful. ;) ​
Link to comment
Share on other sites
Mine were working sometimes, not all of the time. Tried cleaning the outside and spraying with electrical contact spray. It didn't make much difference. They were 'sort of' fixed under warranty, they didn't fail quite so much, but still failed occasionally.
I recently had a tow bar fitted, and the bumper was removed to fit. My goodness - you should have seen the muck and grit inside the bumper!  While it was off, I cleaned it out and used a hairdryer to dry the little electrical plugs that are fixed to the inside of the bumper that connect to the system.  Hey presto!  My reversing sensors are now working 100% all of the time.
Edited by Morgana
  • Like 1
Link to comment
I've just taken the bumper off and removed and cleaned all the sensors. It was dry and just a bit dusty inside and all the electrical connections were dry, clean and bright. I'm having problems finding new sensors at a sensible price. I bought a pair from E-bay that were supposed to fit but didn't. The only genuine ones I can find in the UK are over  £50 each. A bit much if the fault is elsewhere. The Part number is 5JO 919 275 so if anyone can find them cheaper or can suggest a possible different fault I'd be grateful.
Link to comment
Link to comment
  • 7 months later...
A VCDS scan will tell you which sensor is the culprit, one dud brings the whole system down.
I have peeled the limo tints off the rear windows for the time being so I can at least sight reverse, I'll have the bumper off in the summer and fix it with shrink wraps on all of the connections to ensure they remain watertight.
I've seen a You Tube clip that says you can hear the good sensors clicking when reverse is engaged - it didn't work for me though
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
