Turbo Police siren noise after remap... GT1749vb
Recommended Posts
You need vcds lite to be able to set the stop screw.
Basic settings group 11. Engine increases to 1400rpm and cycles from actuator on to off. You monitor the pressure difference and for a stock gt17 your aiming for around 130-150mbar on a warm engine.
Once stop screw is set then you can set the actuator so it hits the stop screw at around 18 on the vacuum gauge.
Link to comment
Share on other sites
I have been back to Big Fish today and they have done logs, on both standard pd150 and pd130 maps. The outcome being the same every time, Overboosting constantly! (2988.00)
The actuator seems fine and hits the stop screw at bang on 18 on the vacuum gauge...
N75 valve was also checked and nothing wrong there along with all vac pipes...
I take my hat off to the lads at Big Fish Tuning, they have done all they can to try and get to the bottom of it!
They think the vanes in the turbo could be permanently closed which is causing the overboosting...?
  • Like 1
Link to comment
Yup. What a pain.
Sure is. And the turbo is still under warranty but because I got it from someone who bought it from turbo active I might have to pay for the turbo to be sorted what ever the problem may be! :/
Here's the logs from yesterday anyway when a stock pd130 map has been put back on...
Link to comment
So by 2400rpm the ecu has fully opened (what it think anyway) the actuator to try and release all the boost pressure due to the over post.
It looks that way yeah, could it be just the actuator rod being too short or could it be a problem with the vanes?
Link to comment
No way of knowing without investigating.
With a vacuum gauge does the vnt lever move smoothly? Or disconnect the arm from the lever and move it with your fingers to see if theirs any resistance.
If feels ok the. Lengthen the actuator arm 4 turns and log again.
Link to comment
It seems the turbo is still under warranty but as for the over boosting the police siren noise is getting worse so it must be the bearing... So the turbo is coming off next week and being sent back to resolve the problem!
Also just bought a GT1749va from a fabia vrs so will be putting that on for the time being!
Link to comment
Im just curious as to what Turbo Active will say reguarding the warranty.
It hasnt been touched or messed with but they usually worm out or any warranty so...
Failed bearing... im expecting "oil pressure problem" to be a reply or somthing similar...
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
