Recommended Posts
Hi All,
Is there an efficient DPF cleaner liquid which I can use in fuel, before fueling?
DPF light on my car is never blinked or switched on, but the smell of the exhausted gas is really smelly. When I bought my car it was not smelly.
I always kept the DPF regeneration.
Which is the best DPF cleaner liquid which really efficient?
Thanks in advance.
Link to comment
Share on other sites
I don't know it is full or not, maybe yes, but the regeneration should be burn the ash.
If the light switched on permanently in that case, I should be replace the DPF. is it correct?
I just would prevent the exchange of DPF, with cleaning of it at first, because a new DPF is really expensive.
Link to comment
A regeneration is only able to burn off soot, leaving an amount of oil ash. This is why DPF filters have a service life as once it's full of oil ash it'll need replacing.
Personally, I wouldn't add any DPF cleaners on a CR engine as I doubt they are needed. It's well designed with the DPF is close to the engine so should be hot enough to burn off the soot on a normal highway run.
If your engine is in good condition and not burning oil then the DPF should be fine for 200000-300000km assuming the car is able to regen when needed.
Link to comment
Just go drive a few miles at 60 in 4th.  If that doesn't burn it off there may be something else wrong.  My car quite often stinks but being a taxi it does a lot of small runs so not really ideal for emissions strangled dervs.
A garage should be ale to do a forced regeneration if it is not doing it itself.
Mine will do a regen in the middle of town, once amusingly at lights at 3am with my colleague behind me.  Looked like an 80s pop video all lit up by his Xenons
  • Like 2
Link to comment
I would LOVE to be able to do this on command, unleash a dirty cloud onto a tailgater.....
  • Like 1
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
