Door switches, window motor and loom.
Recommended Posts
Ok I have in the past repaired and then replaced the drivers door lock, I have also done the strip down and clean the connector to the window motor, I haven't touched the loom but that is because it was all ok last time I looked (about four years ago
Link to comment
Share on other sites
Address 17: Instruments Labels: 1U0-920-xxx-17.lbl
Part No: 1U0 920 911 B
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 23412
Shop #: WSC 25028
VCID: 2E591061EA0C649
TMBSL21U228541536 SKZ7Z0A1032926
1 Fault Found:
01336 - Data Bus for Comfort System
49-10 - No Communications - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 31480
VCID: F0E54E19B0B8B29
2 Faults Found:
01331 - Door Control Module; Driver Side (J386)
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 B
Component: HALDEX LSC ECC 0006
VCID: 1F47FDA59DA6FD1
No fault code found.
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 3Y Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 31480
VCID: 36693801125C5C9
Subsystem 1 - Part No: 1U6959802D
Component: 3Y Tõrsteuer.FS KLO 0002
Subsystem 2 - Part No: 1U6959801D
Component: 3Y Tõrsteuer.BF KLO 0002
Subsystem 3 - Part No: 1U0959811D
Component: 3Y Tõrsteuer.HL KLO 0002
Subsystem 4 - Part No: 1U0959812D
Component: 3Y Tõrsteuer.HR KLO 0002
7 Faults Found:
53-10 - Supply Voltage Too Low - Intermittent
00932 - Electric Window Motor; Drivers Side (V147)
62-10 - No or Incorrect Adjustment - Intermittent
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
27-00 - Implausible Signal
00930 - Locking Module for Central Locking; Rear Left (F222)
00931 - Locking Module for Central Locking; Rear Right (F223)
End ---------------------------------------------------------------------
Link to comment
So the question is what is involved in using golf motor? 1J2959802C seems to be the same part and I know I need to transfer coding ad listed in the scan above but will CCU take golf part connecting to it?
Link to comment
Golf mk4 window motors won't fit Octavia as far as I know. I'm sure they're mounted differently. All those faults normally point to corroded pin in the loom plug and control unit on the motor.
Edited by Guest
Link to comment
35-00 - -
Ok stripped the door down and got the connector off, still full of proper electrical silicone sealer from last time, no sign of pooled water. Got the connector separated from the window motor and it still has all its pins, gave a few of them another clean. Put it all back together and it seems to be back to how it was previously, IE drivers door not locking in central locking and drivers door mirror not working. And the codes above. Stripped the door jam apart and loom looks ok so I guess the original problems are down to the CCU?
Link to comment
Not had the connector out from the CCU yet. Had a good look at the cables where they go through the two grommets in the door and the pillar but not the end. Does it suffer corrosion or other problems?
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
