Have a new iPhone SE,but it won't connect with the mdi wire
Recommended Posts
Hi there
I have got a new iPhone SE to replace my old iPhone
So I got a new mdi wire to connect the iPhone SE with my swing CD player
The swing does not recognise the iPhone. The iPhone comes up the message saying not compatible with the new cable but it will charge the phone up.
Thank you
Will_nfs
Will Parker
Link to comment
Share on other sites
The MDI interface in the Rapid is just the same - a glitchy unreliable piece of poo.  Is the Fabia one the same?  Can you connect with Bluetooth instead?
Edited by camelspyyder
Link to comment
Hi there
Thank you
Will_nfs
Will Parker
You might have better luck using an adapter on the end of the old cable. I know this has worked, with the iPhone 5/6, for other MDI cable owners.
Link to comment
Thank you. Buying the adapter has worked
What adaptor / cable are you using? I have my iPhone 5S connected via Blutooth but it won't bring my music up. All it will do is work as a phone. I tried using my phones lightning cable on the car but it said it was not supported. I use a USB stick full of music from my iTunes instead Edited by Guest
Link to comment
Ah I'm guessing they don't go into the USB / 3.5 mm MDI slots that I have down near my centre console. Your cable must connect to the rear of the radio somehow?
Edited by Guest
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
