Essential Maintenance on 2nd Hand 2,0 vrs?
Recommended Posts
Hi all,
So having just bought a 2006 2.0vrs, I'm looking at things I need to sort / check / change.
I've got a list so far from researching various sites and forums. Is this all overkill, or a good idea to go through each, and is there a good order they should be done in:
  1. Change fuel pump cam follower
  2. Change the diverter valve
  3. Change high pressure fuel pump
  4. Change the PCV front valve
I'm sure I read about some gauze thing stopping oil getting to the engine? But I can't remember what / where that was?
Anything else that would be advisable to check / change?
Edited by Einriba
Link to comment
Share on other sites
The gauze part you mention may well be the oil pick up pipe and this is located via removal of the sump.
That's the one.
A friend has the vagcom cable / software so we're off out logging boost etc to see if it's all operating properly. If so, I'll leave alone. "don't fix what isn't broken" and all that.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
