Honest John reports low torque issue with cheat fix
Surely some motoring show, magazine or forum will check out post-fix performance?
I am damn sure the amount of cars that have now been done in the VAG range if there had been the slightest issue... by god the press would have heard about it!!!!! talk about "S*** hit fan" ... as there has been no press and bad publicity I can only presume that all the issues the press said "you will get" were lies...as usual with the press.... lies sells newspapers....
There must be 1000's of cars done now... have you also thought that some issues may be "in the owners head"?  "I have had the fix now issue xyz" ....
In fact I had my car services a few weeks ago and the DSG seemed to change funny...maybe just me as it is OK now...
In my opinion the lack of bad publicity is a good sign, along with reports I have had from Audi owners...
  • Like 2
The weird thing about that HJ article is that the owner of the vehicle reported a "clatter", isn't that audible noise?
I don't see where the justification comes from to interpret that as a torque reduction.
If there is an issue then it'll take time for the faults to reach the media.
It took at least 6 months for the issue with the injector recall to hit the mainstream media, and this affected all PD170 engines across the whole VAG range. Sometimes it takes time for the effects of the fault to be seen.
If the software patch has lowered emissions during everyday driving (and not just when it was in cheat mode) then there HAS to be a trade-off somewhere.
I imagine the vast majority of owners won't notice, it's just a car to them. Others however will.
The fact Honest John has mentioned it, and there has been a member on here who isn't happy post recall suggests we'll hear more.
Whether it gets reported in the news will depend how much more we will hear over the coming months.
Sent from my Kestrel using Tapatalk
Edited by silver1011
In my view every driver knows their car, they spend time in it, listening to it and soon know if something is not right,
So in that case it is a perception matter, but if an owner feels that the fix has changed their car for the worse then they are entitled to that opinion. .
I think we will see more of these issues coming out.
Stubie
If they reduce the emissions it's bound to affect performance, that's why they had to cheat
The cheat wasnt for normal driving times tough, i read it only kicked when the vehicle ran in a straight line for several minutes at a constant speed..... hardly real life driving
As no car that has left the factory is likely to be tested ever again and the cheat was ONLY for test time why call them in for a fix?
How Did the System Work?
The software sensed when the car was being tested and then activated equipment that reduced emissions, United States officials said. But the software turned the equipment down during regular driving, increasing emissions far above legal limits, most likely to save fuel or to improve the car’s torque and acceleration.The software was modified to adjust components such as catalytic converters or valves used to recycle some of the exhaust gasses.
Edited by lichfielddriver
It's this simple: without the cheat, the cars are NOT compliant with the emissions regulations they are obliged to meet. The cheat mode allowed the cars to operate in an emissions compliant state under testing conditions. Outside of test conditions, the car would operate differently with emissions that are outside the allowed levels. The fix is required in order to make the cars emissions compliant.
You can be damn sure that the fix will be independently tested on cars that have gone through the update process. For one thing the regulators will want to see that the cars are now emissions compliant. Beyond that, the level of coverage the problem has received in the media means there are plenty of interested parties out there who will want to see what has been changed.
It is actually possible to drive in emissions compliant mode on the road (i.e. trigger the cheat mode), it's just not a lot of fun and requires far too much of your attention to be focused on engine speed, gear selection and road speed to be safe.
Stubie
The placebo effect is significant here.
There's a huge amount of negative expectation surrounding the fix due to the media coverage and discussions on forums like this one. That will colour your perception of any oddness that occurs in your car after the fix is applied.
Think about how you feel driving your car after a service. It often 'feels' better as a result of the service, even though there might be no objectively measurable difference in its performance afterwards. You expect the car to be working better after a service so it feels that way.
Conversely if something feels off afterwards, you might blame the service. The car has had work done and something is wrong afterwards so again there's a subconscious association between the two events even if there's no objective reason for it. The most common manifestation of this is when something that was failing anyway happens to fail just after a service. The immediate conclusion is that the service is to blame for the failure, but in reality it's just an unfortunate coincidence.
Really, what we need to see here are some proper lab tests carried out on several cars under identical conditions before and after the fix is applied. Full dyno run, emissions test, noise test. Organisations like TUV and AA need to step up to the plate here.
Had my Skoda superb done last week and it feels like you need to give it more throttle when driving slowly, as it feels like it wants to stall in 3rd
Probably running a higher EGR rate than before.
Presumably no noticeable difference at high power levels (EGR inactive then).
Just recently had my 15 plate 2.0 140 Bus. edition estate recalled and updated.
For the record there's a louder exhaust note (in cabin) and a slight dip in performance and economy...this is extremely marginal but after 67K in one year from new I feel I know the girl.
