wheel bearing replacement
Recommended Posts
IIRC, at my local dealer a front one was about £200 inc. the bearing and VAT.
Link to comment
Share on other sites
There was a intermittent  whining noise from the rear of my 06 octy , thought it was a bearing , so got one intending to do it myself it cost  £100 approx. (Hub and bearing ) but then had a puncture,  changed wheel then noise gone , it was the Dunlop tyre making the noise on some road surfaces.
Link to comment
Wheel bearings are fairly easy to do on the drive I did a rear on my vrs when the abs ring failed as it's part of the bearing,
Bearing from euros £70
Remove disc from said wheel
Remove bearing cap with screwdriver
M14 splined socket and 3ft breaker bar
When m14 bolt removed bearing simply falls off
Reverse to fit new bearing
Link to comment
Bearing from euros ?70
It's the torque that's mental on the rear. 180 Nm plus 180 degrees iirc.
  • Like 1
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
