boost pressure drop in 3rd 4th 5th around 5000rpm
Recommended Posts
Hi all i am new to this, Im on my second octavia rs 2003 1.8t. it does seem to be remapped also cat back exhaust and k&n panel filter
I have a problem the car drives fine in first and second but sometimes it seems to drop boost around 4-5rpm. So for instance in 3rd it will pull strong to around 5rpm then all of a sudden feels like i have put my brakes on and the car looses all its power..
got no cel light no obvious problems
Edited by gsaiev1987
Link to comment
Share on other sites
mine has started to this but much lower in the rev range about 3500 on half throttle. you can actually here it dump the boost on the DV continue like normal afterwards.
my intital process will be
boost leak check because theres a million pipes and connections that fail regardless of how much silicone hoses and checks i do
N75 value i want to see what it does when i data log this when it does make the flat spot/loosing boost.
the dump value it self i want to make sure it can still hold boast correctly
both those units for me are under 2 years old and OEM units for me so i don't think they will be the problem
The next 2 are more tricky to diagnose as there more age related i think could be the issue is the fuel pump because i know its original and I'm asking it to work harder (my car is stage 2)
The last is the actuator and turbo it self again i know both are original so they are suspect
I'm sitting on 110k miles now and been remapped from 60k
Link to comment
Hi all thanks for all the comments. I have posted a video here please have a look. im in 2nd gear to start which revs all the way to redline with a few judders or so, But as u can see when i go into 3rd it stops and feels like im hitting a rev limiter at 5k.. this does not happen all the time. You can hear the car
http://<embed width="440" height="420" type="application/x-shockwave-flash" src="http://v9.tinypic.com/player.swf?file=359epo5&s=9"><br><font size="1"><a href="http://tinypic.com/player.php?v=359epo5&s=9'>http://tinypic.com/player.php?v=359epo5&s=9">Original Video</a> - More videos at <a href="http://tinypic.com">TinyPic</a></font>
http://View My Video
Link to comment
Link to comment
Crank sensor throws a 16706 code Iirc and EPC light comes on and will be difficult to start. Also check your brakelight switch, its dual circuit and will cut the ECU randomly if faulty though brakelights may still operate. Had a stage 2 4x4 and this cost me a lot of time and money to track down to the brakelight switch. Both parts about a tenner non OEM. As suggested get codes read.
Edited by modra_vrs
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
