Help please
Recommended Posts
I have a vrs Octavia pd170 not been used for a few weeks took it for its mot drove fine there then on way back starting playing up lose off power at junctions managed to get it home went to it yesterday morning started it up tickover is rough and accelerator pedal unresponsive anyone any pointers
Link to comment
Share on other sites
You need someone with VCDS, not just a generic fault code reader.
VCDS is tailored to VAG car and gives much more detail on the fault...
http://www.briskoda.net/forums/forum/23-diagnostics-vcds/
All respected fault finders use VCDS from Ross-Tech. If the guy you have coming doesn't have it then find someone else.
Link to comment
right guys help needed on this if anyone got and ideas no accelerator pedal operation if you keep your foot to floor eventually starts to rev in garage at mo done all diagnostics no fault codes check accelarator pedal operation all ok
Link to comment
You said the car was parked up for a few weeks has water got in somewhere and causing problems i know on some audis and golfs the ecu can get water on it or damp if the drain holes under the windscreen area are blocked and cause throttle problems,also a faulty brake pedal switch can cause issues as when the car thinks its braking it cuts the throttle just some suggestions .
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
