Gtb1756 boost pipe fitment
Jrjg
Recommended Posts
I am having problems securing the lower boost pipe onto the turbo, mainly due to the 'lugs' on the turbo pipe itself. Putting the silicone elbow over the lugs was a no go as neither a jubilee clip or hydraulic type mikalor clamp could create a seal due to the offending lugs. This left me with the option of putting the clip on the end of the turbo pipe, with only an inch or so of purchase. This in turn meant the silicone elbow rubbed against the wheel arch and started to split open (it managed to wear through to the 'thread' layer of the silicone), I have solved this dilemma by simply chopping a strip from the wheel arch to prevent it from happening again. However antics (completely legal... :bandit: ) with a Porsche this weekend have pushed the boost pipe off the turbo and against the droplink, splitting it on the already weakened section too. Resulting in a serious boost leak, such a hiss like I've never heard, so I drove home off boost and have dusted off the push bike instead.
I have ordered a fresh elbow but obviously want to prevent the same thing happening.
My ideas are: buy a 'constant pressure' type jubilee clip, the expensive ones, and try the current position.
Apply some form of glue or bonding sealant to the turbo pipe and then fit the boost pipe (downside to this would obviously mean cutting the pipe off should I ever need to remove it, also would glue melt/soften with the temperature from the turbo pipe?)
Or to find out how the Audi A6's boost pipe was secured to the turbo; I'd assume the use of the lugs, and modify something around an Audi A6 boost pipe.
I would like to of cut the lugs off the turbo but don't want to compromise or weaken the outlet. Not to mention the time spent to take the turbo out.
Any suggestions are very welcome and appreciated.
JRJG
Link to comment
Share on other sites
Got a pic?
My 1756 just had a normal outlet that a mikalor/jubilee works with perfectly
I'm about to jack it, axle stand it and crawl under so I will see what kind of picture I can get.
Bought some 'T Bolt' jubilee style clips from Darkside, so that option is covered, fingers crossed they will have a better grip/hold than the standard jubilee clip on currently.
JRJG
Link to comment
That's just a normal outlet,your pipe should butt up to those lugs,not go over them.
What diameter pipe are you using?
If your silicone pipe is touching the arch lining you need to cut it down before fitting,a standard 90 degree elbow usaully come with a 100mm leg length which is way too long.
Link to comment
That sounds like a solution to problem number two.
I will refit in the same position with some of these 'improved' clips and all being well it should hold. The original one was from DS in their hard pipe kit to fit a gtb, so I would assume it is the correct diameter, I have ordered a new one that is definitely the correct diameter, I will compare the two when it arrives.
Thanks very much for your replies!
JRJG
  • Like 1
Link to comment
The Samco 90 elbow works well (i use one rather than the DS one on 2260) and gives more room...........however, ideally you need a longer one and clock the turbo housing one notch to give you more clearance..........................
  • Like 1
Link to comment
Fitted the new pipe just now. It seemed a lot tighter than the previous aged one, although I assume they do stretch slightly over time?
I see what you mean now Stuart about rotating the turbo slightly to gain a bit more clearance. cab this be done with the turbo in situ or is it nearly impossible unless removed? Also, would it even be possible without altering the downpipe? (Or am I talking dribble).
JRJG
Link to comment
To give an idea of how tighter it was - I couldn't stretch the pipe over the lugs, something that the previous pipe could do with reasonable ease.
Perhaps this tighter pipe will be all I needed to prevent it blowing off again!
Link to comment
JRJG
I've heard people saying they can rotate the housing with it still on the car but not sure i believe that!
Link to comment
Yeah I can't imagine it being plausible.
Unless you have baby sized hands.
JRJG
Link to comment
I rotate the housing with the turbo (GTB1756) fitted, it was roughly in the correct position but needed a tweak to get the best alignment of the pIpework.
I would think it's pot luck getting it in the correct position first time when it's on the bench.
There was nothing hard about it, 10mm bolts if I remember correctly.
Link to comment
Can you remember how many there were, did you do it from underneath reaching up into the bay? Mine will only need a very slight rotation, 15 degrees or so, next to nothing but it will give the boost pipe a little bit more clearance and stop any future possible rubbing from happening.
I just got a 60mm 90 bend put it over the top jubilee clipped it and hasn't blown off under stick
If only that were the case for all of us!
Link to comment
Rethinking the clocking. It won't be possible unfortunately. The reducer pipe from the turbo to turbo intake is already too short, in an awkward 'trying to be a swan neck' position.
By rotating the turbo further clockwise, to get the clearance on the bottom pipe, it would not leave enough purchase for the intake pipe, nor would the angle be appropriate. Thanks for the suggestions though everyone. In the ideal world that would be a good solution. I might wrap the pipe in some form of protection, on the most likely areas, to prevent any rubbing damage. Always something isn't there.
JRJG
Link to comment
JRJG
Eh?
The intake is central,so clocking the cold side of the turbo will not make any difference to the inlet! :)
Link to comment
Eh?
... Oh well in that case ...
Can you tell I'm an absolute amateur? :D
JRJG
  • Like 1
Link to comment
So I checked the elbow again this evening and sure enough it has pushed its way against the droplink again.
I will take it off tomorrow, trim it, and refit it with a different clamp. But how much should I cut off?
I am assuming an inch or so to begin with, and try it for size, then cut again if necessary. Any tips for clean cutting silicone pipes? A hacksaw?
JRJG
Link to comment
Ideally you want a brand new Stanley knife blade,and a piece of hard pipe the correct size and cut the silicone with it fitted to the hard pipe.
As long as you have enough straight pipe left to get the clamp on you can cut it as much as you want :)
Link to comment
Just finished putting the arch liner back in.
I wrapped plenty of tape around the brand new (!!!:@) elbow's wound. It hadn't worn through all the way through but had got through the first layer, only done a couple of hundred miles. My ignorance for not checking it sooner.
Your method would of been ideal but my weapon of choice was a hacksaw, made a reasonably clean cut, not that it matters I don't suppose.
I also zip tied the new T Bolt clamp (on the boost pipe end) pulling it away from the droplink via a second loop through a convenient bolt hole in the sump. So that should keep it from coming anywhere close to the droplink and wearing through again.
Thanks for your suggestions
JRJG
  • Like 1
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
