Cleaning rear brake shoes
Normski55
Recommended Posts
Hi all. The rear brake shoes are not adjusted correctly meaning the handbrake works well on one side, but not the other. I've had a quick look and the shoes seem OK so I'm going the give the linkage mechanism a good clean up with brake cleaner and the reset the adjustment on both sides. What I was wondering is, if I get any brake cleaner on the shoes will that be a problem or is this something I need to avoid at all cost?
Any other advice would be much appreciated as the MOT is due at the end of October.
Cheers, Normski.
Link to comment
Share on other sites
That's a good point about the cable, I will check it. When I took the drums off for a preliminary look, the side that doesn't work very well came off really easily and the side that does work was a struggle off making me think the good side was adjusted up and the bad side not. I aim to get them both set up correctly and see if that improves things. When the drum is off, I presume I should be able to see if the shoes move out if I get someone to pull up the handbrake slightly?
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
