Nox Emissions Software Update
glenn_btn
Recommended Posts
Just got my letter from Skoda this morning telling me the fix is now ready for the EA189 software update on my Yeti.
Who's going to bother getting the update?
They say it won't change anything but I am not convinced
Glenn
  • Like 1
Link to comment
Share on other sites
It seems the Germans claim that its removal will have no effect because it wasn't needed for EU certification, only the U.S.
from that I take it that it was convenient to have a single production line (relating to the ECU) for all markets AND on that basis there would be no compensation, just a 'technical' removal.
VW even suggests that outside of the U.S. nothing was illegal.........that's debatable I'd have thought.
  • Like 1
Link to comment
I had mine serviced last week......not even mentioned
tomorrow it's back for aircon and brake fluid (aircon machine broke).....I'll ask Rainworths.
Personally I don't care
Having worked in IT (now retired) I know how many times I was challenged to tweak things to make things appear or disappear for all sorts of accounting, marketing, PR, legal loop holes etc. I beleive such practices are rife and no different to any other maximising of business opportunity.
I also know IT people love to be clever and beat the system.....I know I did
  • Like 2
Link to comment
Read somewhere (may have been a thread in General) that a number of Tiguans that have had the update now run like a bag of spanners and VW don't have an answer!
If it was me I wouldn't have the update done and risk a good running car being ruined.
Link to comment
Our Toledo/Rapid apparently has one of the 'dodgy' 1.6TDI's, however if the intention of any suggested fix is to further gag the engine to force it to meet the perimeters it was supposed to meet, then I can only see this causing potential running and reliability issues.
So I will not be accepting any fix, as for me the engine was designed mechanically and electronically to run the way it is.
TP
  • Like 1
Link to comment
TP
The 1.6 fix does involve some part changes as well as a CPU tweak. If I still had a TDI I certainly wouldn't be getting it done until plenty of positive reports go online from early adopters and the motoring press have done some before and after testing.
Link to comment
See here: http://www.honestjohn.co.uk/news/volkswagen-emissions-scandal/8-reports-of-volkswagen-tiguans-losing-power-after-ea189-emissions-fix/
(and read the comments too...)
Edited by muddyboots
  • Like 1
Link to comment
Strangely I received my first communication from Seat regard this issue today; basically they are letting me know that a fix for my car is not yet in place but the intention is to do so by the end of the year and have the car recalled sometime next year.
They have given an e-mail if I have any concerns, so I will probably use it to let them know that my only concern is the carrying out this recall in the first place  :D
Will also request that they remove my car from the campaign list and see what response I get if any.
TP
Link to comment
Glenn
I'm going to have my car 'fixed' as it will be at Skoda's expense.
I have NO idea what damage its done to the DPF or the trade in value or resale value???
Link to comment
Why would it have damaged the DPF?  NOx (nitrogen oxides) are gases, not particulates.
My understanding (could be wrong!) is that increasing levels of EGR can cause more soot production - so if the fix involves increased EGR (to reduce NOx) then potentially you'll get more frequent active DPF regeneration, which in turn could lead to ash building up more quickly and DPFs requiring replacement earlier.
Not "damage" to the DPF as such, just a possible shorter lifespan - though no doubt still well outside of warranty periods....
Link to comment
AFAIK
The SCR permits sustainable high combustion temps thus reducing soot content, giving a cleaner burn, higher power (eg Mercedes Bluetec 2.0L gives 150kw ~ 200bhp) and better economy.
The high temps produce NOx BUT the SCR (adblue injection) eliminates 90% thus no need for recirculated exhaust gas via the EGR valve and cooler.
But for low mileage (and thus adblue use), it seems there is a risk of crystalline fouling due to the age of the fluid in the tank.
Pluses - cleaner DPF , more power, better economy, no EGR issues and less need/frequency for regens
Negative - SCR injector failure due to low annual mileage .
Edited by Ryeman
Link to comment
I received a letter from Skoda regarding the EA 189 Service Action this morning , as I bought the car second hand I hadn't actually given this any thought , and I wasn't expecting to hear anything .
Anyway it seems the fix for my Yeti isn't available yet , and I'll be contacted again when "the specific technical measure for my vehicle is released". I guess it's good that my car is in the system now .
Edited by Clive
Link to comment
Got mine too today
Mines a 140 TDI DSG....wonder if the DSG version is a later version to be released...hope its better than the Tiguan one
In any case I have no current plans for my vehicle to be updated!
Link to comment
I'll wait to see what my next letter says before I decide whether or not to have it done , but I probably won't .
Link to comment
My reading of your previous post was that you thought the NOx issue might already have damaged your DPF.  Your explanation above - that the fix might have that result - makes more sense, though I've no idea whether or not your technical exposition is correct.
(My understanding is that regeneration involves burning off the soot ie carbon particles, which will simply product CO2 with no/minimal ash.  But I might be wrong.)
AFAIK
The fix for the NOx issue on EURO5 engines doesn't involve retrofitting an SCR, adblue etc.  Or have I misunderstood your post?  (I thought you were replying to muddyboots but I may have got confused.)
However, your explanation of the pros and cons of adblue is useful, so thanks for that.
Link to comment
Got mine as well
Link to comment
Got my fourth letter today (the first was October last year..) to say they are still working on an update for my specific vehicle - 170 manual L&K
Odd how some are ready and others not...
Edited by PaveyArk
Link to comment
Seems to me that given reported problems with e.g. the Tiguan that VWG are delaying implementing the fix for other models?
They were already late with beginning the first "fixes" and little progress seems to have been made - no one on here has reported having the fix done yet.
VWG seem to be dragging this out and the emails are just to placate owners that they are doing something.
Perhaps even now they haven't got the promised fix i.e. one that doesn't affect power, running characteristics and economy and are hoping if they drag it out long enough that the problem will go away, well outside of the US anyway.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
