Brake pad wear indicators
Recommended Posts
Car was services this week, where it was noted the rear brakes were had about 25% left and would probably be okay for another 10k miles (ish) as most of the braking is done on the front.
Two days later (and not 10k miles later...) the rear brake pad wear indicator flagged on the maxidot.
Are the indicators overly cautious in terms of triggering, or is it wise to follow them?
I'm not familiar with what to look at physically on the brakes to see what wear level they're at
Link to comment
Share on other sites
My car is at 58k miles and still on its original pads with loads of life left in them, so quite normal for a diesel that will use engine to do a lot of its braking (for most people)
Link to comment
There is no rear pad wear indicator I'm aware of. The only sensor for pad wear is in one of the front brake pads. You'll see a wire going to the brake pads on one of the front calipers. It's possible the ABS pump is doing something fancy to track the position of the rear pistons, but I've never heard anyone mention this.
Link to comment
You're right psycholist, no wear indicator in the rear pads - gave the garage who did the servicing a call and they took a look this afternoon
Inner front of the pads has worn through unevenly due to scoring on the discs straight into the wear sensor
Plenty of pad left either side, but ideally need new front pads/discs - thanks all!
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
