VCDS - Autoscan_issues
Recommended Posts
i've noticed that recent autoscan reports done on my 03 Fab saloon haven't reported on certain modules, even though the modules appeared to have been selected for autoscan in VCDS and are installed in this particular model - 1.4 16v 100 HP BBZ engine, manual 5 speed, 6Y chassis.
For example. An autoscan done on 10/10/2016 reported selecting the following modules for autoscanning:-
01, 02, 03, 08, 09, 15, 19, 25, 37, 44, 46, 55, 56,76.
And it actually reported on 01, 03, 09, 15,17, 19, and 44.
It failed to report on 02,  08, 25, 37, 46, 55, 56, 76.
Now I can understand why it didn't report on some modules because they aren't insttalled on this vehicle:-
02 - auto transmission
37 - Navigation
55 - xenon range
56 - radio ( I have aftermarket radio installed)
76 -park assist
However, it failed to report on items which are installed and which prior scans (2013) did report on:-
08 - HVAC
25 - immobiliser
46 - central convenience
Any idea on the reason for this ?
Is it possible to do a manual scan for these modules ?
VCDS version 16.8.2
Data version 20160926 DS261.0
Nick
Link to comment
Share on other sites
Downloaded the latest version, 16.8.3 and autoscanned and the same happened.
It only detected controller modules 1,3, 9,15,17,19, 44 and 46
It failed to report on 2,8, 25, 37,55, 56 and 76.
It should have reported on 8 and 25.
So, I tried doing it manually through the select control module option and got the following:-
08 - No response from controller
25- Partial response from controller -  but access to advanced measuring values was  denied (Greyed out).
And this was the autoscan.
VCDS
Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: Release 16.8.3    Data version: 20161010 DS267.0 www.Ross-Tech.com
Dealer/Shop Name: Workshop Code: 000 00000 000000
Self-Diagnosis Log Monday,17,October,2016,18:01:26:08693
VIN: *****************   License Plate: **** *** Mileage: 99790km-62006mi
Repair Order:
Chassis Type: 6Y (6Y - Skoda Fabia (1996 > 2008))
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
VIN: *****************  Mileage: 99790km-62006miles ------------------------------------------------------------------------------
Address 01: Engine
Labels: 036-906-034-APE.lbl
Part No: 036 906 034 DF
Component:  MARELLI 4MV        5020
Coding: 00071
Shop #: WSC 25021     VCID: 59B3E0EDC338878A9B-4B18
*****************     SKZ7Z0B1485705
1 Fault Found: 18043 - Powertrain Data Bus
      P1635 - 35-00 - Missing Message from A/C Controller Readiness: 1110 0101
------------------------------------------------------------------------------Address 03: ABS Brakes
Labels: 6Q0-907-37x-ASR.lbl
Part No: 6Q0 907 379 H
Component: ABS/ASR 5.7 FRONT   V20
Coding: 00124
Shop #: WSC 13765     VCID: 428127814EAE2452EA-5120
No fault code found.
------------------------------------------------------------------------------Address 09: Cent. Elect.
Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 C
Component: 00 BN-SG.           1S33
 Coding: 17418
 Shop #: WSC 25040     VCID: 3B7F5A652944559AA9-5120
VCDS Self-Diagnosis Log Monday,17,October,2016,18:01:26:08693 Page 2
Address 15: Airbags
 Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 601 C
Component: 02 AIRBAG VW51      0004
Coding: 12338
Shop #: WSC 13765     VCID: 20458D09A0E216429C-5120
------------------------------------------------------------------------------Address 17: Instruments
Labels: 6Yx-9xx-xxx-17.lbl
Part No: 6Y2 919 880 B
Component: KOMBIINSTRUMENT VDO V12
Coding: 16442
Shop #: WSC 25021     VCID: 46893B9162861872C6-5120   *****************    SKZ7Z0B1485705
------------------------------------------------------------------------------Address 19: CAN Gateway
Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 33 GATEWAY  CAN    1S33
Coding: 00014
Shop #: WSC 13765     VCID: 70E5BD493082E6C24C-5120
------------------------------------------------------------------------------Address 44: Steering Assist
Labels: 6Q0-423-156.clb
Part No: 6Q0 423 156 M
 Component: LenkhilfeTRW        V210
 Coding: 00140
Shop #: WSC 13765     VCID: 3973406D2378678ABB-5102
VCDS Self-Diagnosis Log Monday,17,October,2016,18:01:26:08693 Page 3
VIN: *****************  License Plate: ****_***
Address 46: Central Conv.
Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 31 Komfortgerát     0001
Coding: 00067
Shop #: WSC 13765     VCID: 3D7B547D37505BAA97-4AE6
   Subsystem 1 - Part No: 6Q2959802   Component: 31 Tõrsteuer.FS TFK 0002
   Subsystem 2 - Part No: 6Q2959801   Component: 31 Tõrsteuer.BF TFK 0002
End-------------------------(Elapsed Time: 03:16)-------------------------
There's only one fault code - highlighted red and only a couple of components appear not to be working, the cabin fresh/recirculated air flap and the temperature flap. Heater blower is working but only deliver cold air.
And the battery is being depleted by an on going drain of about .45 amp when the car's at rest, engine off, ignition off and all door and windows closed.
Nick
Edited by Clunkclick
Link to comment
Well, your experience is much as I felt.
The problem is not with VCDS but with my car's electrical system.
At the moment the temperature control flap motor (V168) in the cabin heating system doesn't seem to be working because, no matter where I position the temperature knob on the centre dashboard console, all I'm getting is cold air.
Also, my car has got a constant current drain on the battery, when the engine + ignition is off an all the doors and windows are closed and locked, of 0.5 amp.
My working assumption is that both of these are linked.
To date, in my mind, possible candidates for these failures were either the temperature flap motor or the Air Conditioning control board behind the heater switches on the  lower part of the cabin dashboard centre console.
However, interpretation of the Engine (Module 01) fault code reported above, using Ross-Tech's database, states that fault 18043 -P1635 relates to the can data bus, AC - no signal AC control module, trouble code(s) stored, wiring, matching ECM.
This introduces both the wiring and, unhappily, the ECU, as possible candidates/co-candidates responsible for the faults.
As, I understand that, a new  replacement AC control module  from Skoda is  conveniently priced at £198 (For a 12cm x 3cm single layer electronics board that probably costs less than a fiver to manufacture, distribute and market) and a new ECU is £600 +, and fixing any of the components, other than the ECU, involves a mini tear-down of various parts of the cabin dashboard, I am  wondering if any other features of VCDS can be used to narrow down the cause of these faults/determine whether they are caused by the same thing, or whether its now down to brute force and multimeters.
Nick
Link to comment
When I bought my VW Passat back in 2000, some time later I discovered a suitable NOS Climatronic control panel for sale on ebay, I think that I only paid about £15 for it, when I bought my wife a VW Polo in 2002, some time later I discovered a suitable NOS Climatronic, (or maybe the Polo auto AC was called Climatic) control panel on ebay, I think that I only paid about £15 for that one as well!  I seem to remember trial fitting them and recoding them to suit - but over 13 years of owning both these cars I never needed to use them!
You can make life turn out like that, strange!
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
