Skoda Yeti 2011 Instrument Cluster - Tampering Kilometer reading
Sibu
Recommended Posts
Has anyone heard or experienced  tampering with the mileage on Skoda vehicle cluster panels.
Will it damage the ECU of the car  or is this done after engine overhauling  .
Link to comment
Share on other sites
The only legal reason to "tamper" or change the mileage is following an instrument cluster change where it is corrected to reflect the accurate mileage of the car. You would not change this if the engine were overhauled/replaced.
Link to comment
Obviously it depends on your country's laws, but generally the altering of kilometres/miles is not in itself illegal, but fraudulently stating that the altered distance is correct is.
But as said above, there are few genuinely moral or acceptable reasons to alter the distance. If you replace an engine you simply record when this happened in the service record, but leave the odometer alone. After all, the rest of the vehicle has still covered the original distance.
  • Like 2
Link to comment
Regardless of why, it's completely possible to alter the odometer milage in a 2011 Yeti with the right tools and knowledge.
In some cases it can leave a fault code, especially if done badly, plus the tools are quite expensive.
Link to comment
Could it be that the instrument cluster gets the mileage information stored on the cars ECU
No they are separate.
There was a member on here who purchased a car a while back and it turned out it had been "clocked". Mileage on the dash had been changed but scanning the ECU with VCDS revealed a much higher mileage.
  • Like 1
Link to comment
Can the clocked mileage cluster panel create fault indication like a steering axle indication / ESC indication !!  Skoda claims this is indicated due to a clocked mileage !
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
