Electronics problem
Recommended Posts
Hi. Thanks for looking. So the dash has been on and off over the last 6 months (damp dependent) but now the dipped headlights look like they're on minimal power so I actually have to do something about it. So... Do I do a complete dashboard change ?? Have you done one?? I am actually looking forward to it.
Any tips would be great (steering wheel out?)
Thanks, Billy
Link to comment
Share on other sites
if your headlights are dim that sounds like a battery or earth problem, not electronics
check the voltage on your battery, and at the headlights, I suspect one or both are low
if both are low you likely have a battery / charging problem
if only the headlight voltage is low you likely have an earthing problem
Link to comment
Thanks.
I was working away on the car when I hd a quick look under the bonnet. I wiggled the Alternator leads then gave the headlight a thump and the full beam came back on again
So it was both loose connections or one or the other. Still think the damp in the dash is a problem
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
