Skoda yeti reversing sensors
ark
Recommended Posts
I have skoda yeti MY13. recently i noticed that the reversing sensors stopped working. I used to have graphic pic on Bolero and beeping sounds when the reverse gear was selected. now I have no sounds no pic on bolero screen.
Today I put the reverse gear in without starting the ignition, just to see which sensor was faulty. All of the sensors were working but still no beeping sounds and no graphic pic on Bolero.
Is there any way to get the sensors fixed without taking it to a dealer?
Link to comment
Share on other sites
Try removing and reinstalling the main fuse for the radio. Fuse No 8 under the bonnet - a 15 amp (Blue) one if I remember it all correctly (Leave it disconnected for a few moments for the capacitors to discharge). This will cause the system to re-boot and hopefully all will be well. Don't worry about the radio code, It is picked up automatically from the dashboard (ECU).
This usually works with getting rid of any gremlins that appear spasmodically. Hope this helps - let us know?..............Tony
Link to comment
How do you know the sensors are working if no visual or sound?
Link to comment
Thanks for the reply Tony. I removed the fuse for nearly half an hour but still nothing happened. actually it didn't re boot the radio as it didn't ask me for the code to enter........
If you put the car into reverse with motor running the sensors themselves emit a low beeping sound that indicates they are working,
Link to comment
The car ECU stores the infotainment system code, it saw that it was the same Bolero installed so would not ask for the code.
Are you saying that the sensors themselves emit sound?
Link to comment
put the gear in revers WITHOUT motor running, then you go to back of your car and touch all the sensors then give you clicking noise. that means the sensors are working apparently. I watched it on Youtube and I tried on my car. same thing happened. so I'm guessing the sensors are working but doesn't show up on Bolero and doesn't give me any beeping sounds...
Link to comment
Then it sounds like something is disconnected or broken.
Couple of things to try.
Is the light showing on the sensors button when manually pressed?
Are your reversing lights working?
Link to comment
What sensor button?
The reversing ones don't have a button.
Link to comment
Have a look in the menus to see what the beep volume is set at - perhaps that's turned to zero - wouldn't account for the lack of visuals though. Failing that, it's a dealer visit if still under warranty or a auto electronics specialist if it isn't.
Link to comment
Depends on age?  Mine (see sig below) is off far more than on but the reversing alarm diagram always appears.
And mine. Visual display shows even when radio is off.
Link to comment
I think I have to take it to a dealer or specialist. I checked the beep volume and frequency and I can't change any of those somehow. the number doesn't go up even or down....
Link to comment
If you reverse lights are functional, definitely it is something to do with the sensor wiring . Have you done any repair job on your car dashboard prior to the fault.
Obviously the reverse sensor buzzer must be inside your dashboard
Link to comment
no i didn't do anything on my dashboard. just few weeks ago i noticed that the reversing sensor stopped working and now trying to find where the buzzer is so that i can replace and hopefully buzzer and the screen will work after replacing the buzzer...
Link to comment
Isn't the rear sensor buzzer somewhere in the rear of the cabin and the front sensor buzzer in the front of the cabin? Sounds that way
It is if you have front and rear sensors.
Link to comment
  • 4 weeks later...
I finally fixed the reverse sensor. it was really difficult to fix. I guess it would've been easier if I knew where the buzzer was. I had to remove all the grab handles, all the pillar covers and the roof lining very very carefully as mine has side airbags...
the buzzer was located in the roof at rear of the luggage compartment on the right hand side. it was also difficult to remove the buzzer as it was almost impossible to see and it was riveted.
Id like to thank you all for your time and help.
  • Like 1
Link to comment
  • 3 years later...
Hi Ark.
Don't know if you're still on here but I have the same problem.
I have a new buzzer, Any tips for fitting?
Link to comment
On 14/02/2020 at 20:20, Robjon said:
Ark last visited on 31 December 2016 - so probably not :sadsmile:
Yes I know it was a bit of  a long shot but worth a try😀
I've done it now and put a How to in my other thread here:-
  • Like 1
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
