Carbon Air Intake | MQB
M12MKD
Recommended Posts
For Sale -
Details as below - few very slight marks from fitting (can take pictures if needed) - £200ono delivered
Can include pipercross panel filter for extra
The Revo Carbon Air Intake Upgrade is designed to work in harmony with Revo software to unleash the maximum potential from your engine.
Flow testing of the OEM intake emphasised the restrictions in the system, giving the Revo engineers a clear indication of what needed improving. The stock front panel, used to direct air to the airbox, the standard air filter and convolutions in the rear pipe from airbox to turbo were found to be the main ‘choking points’ in the system.
The Revo system is a direct replacement kit and includes a beautiful carbon front panel, designed to direct cold air directly to the OEM air box utilising an internal fin, along with a second feed of cold air in to the engine bay to help keep ambient temperatures lower.
Carbon Front Section
The Revo carbon front section integrates a direct cold air feed which is blanked off on the standard part, and also includes an internal fin that directs air towards the airbox. Designed to also aid in lowering ambient engine temperatures, the Revo engineering team have integrated a second air inlet to allow a direct cold air feed to the engine bay.
Edited by M12MKD
Link to comment
Share on other sites
What's the extent of the damage?
Its slight scuffing where it connects with the airbox and where the coolant pipe runs over the top. I'll try and get some pictures up today. You have to look in the right light to see them. They will probably polish out.
Link to comment
hi mate, if this is still available after Christmas ill have it. Sorry for delayed reply been away with work! if it sells it sells. GLWTS :)
no problems, drop me a message later.
Link to comment
  • 2 months later...
Guest
  • Community Partner
  • Create New...
