Wing tip to bonnet alignment
Recommended Posts
I was just walking around the nose of my 16 plate Monte Fabia III Estate and I noticed on the drivers side, the very pointy end tip of the wing that meets the headlight sitting a little proud of next to where the wing aligns to the bonnet.
I pushed it in with my thumb and now it matches beautifully with the passenger side, although i'm a bit concerned how bendy that little pointy triangle tip of the wings are! Now I'm thinking, should I have moved it!
Anyone else done this?
Link to comment
Share on other sites
Uh oh! that's done it! lol...I don't think you have caused any harm. Can you actually see any damage to that part of the wing. I mean, is it now out of shape slightly. I've never tried that on mine. I suspect what you were seeing is a very minor misalignment of the bonnet, which is normally adjusted by moving the bonnet hinges. That's if I've understood your description of the issue correctly. So actually altering the pointy wing thingy isn't normally required. But if it's now ok just leave it.
Link to comment
Before buying my wife's Fabia I very nearly bought a different one from another dealer, however upon going to view the car (it was a pre-reg) I could immediately see the bonnet/wing misalignment you describe.  This was, as you'd expect, a complete surprise to the salesman!  Needless to say I walked away.
Link to comment
Your photo's made me go and look at my Fabia and mine looks perfectly normal compared to yours, which stands out as a fault in my opinion.
Link to comment
Could you post a like for like photo of your driver side part of the wing so  i can see?
Link to comment
I'll have a go tomorrow when it's light,for you,unless someone beats me to it with their car picture. There's something definitely not right with yours.
Link to comment
Ok thanks. Here is a side photo of my Fabia wing to bonnet.
Wing 3
Link to comment
Took this picture even if it was dark and tried enhancing in Photoshop:
I'm sorry to say this but yours look a bit bumpy :(
Mine looks exactly the same so no need for me to upload one tomorrow. It needs to be fixed under warranty?
Link to comment
Had a peek under the hood, all looks 100% mint. There is an arm from the wing that's screwed down near the headlight, if you press it down the wing bulges out, quite fun. Seems to have sorted it!
These cars are made out of tin foil these days! In the interest of mental health I'll stop fussing over it and just drive the damn thing haha! It is a beauty tho, bravo Skoda.
Of course these mm imperfections are living proof that we don't live in a perfect world, entropy is only around the corner for all our beloved metal boxes we drive at 80mph into grit and weather and wonder why they pick up micro blemishes and scratches :)
Link to comment
From your photo, it looks a simple job to tweak the bonnet adjustment. That's all it is. It normally involves both hinges and requires just a little knowledge. I've done some really way out wing to bonnet adjustments. I mean it can really looks like the car has had a smash (even though it hasn't), but after some proper tweaking, it's perfect factory type finish.
Link to comment
Good to know these things are easily fixable. What is interesting is that I opened and closed the bonnet after playing with the rubber shock absorbers and it looks seated more evenly, I think it looks normal now from all angles.
I've been trawling through the Fabia III owners picture thread and I see the same thing on many of them!!! Some worse than others. The worst I've seen is on the Chris Evans review of a yellow hatchback, it looks like the bonnet is well out.
Guess it's one of those things, if it's in tolerance it passes when leaving the factory, but if can be improved for us fussy gits.
Edited by Jedispooner
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
