Catastrophe- Run out of oil
markb
Recommended Posts
Short story is that No1 daughter was driving the car when something punched a hole in the sump. I've temporarily fixed the hole and refilled with oil. Engine is not seized, but despite fuel and a spark the engine turns over but will not start. My amateur guess is that the rings may have welded to the piston and the resulting reduced compression is the culprit.
Anyone got any suggestions about repairing it? Is it even worth it? It's done about 30k miles and is 4 yrs old.
Link to comment
Share on other sites
Posh answer - Compression test it
Rough arsed answer - for a quick sign if it is terminal, take a plug out and put a long rod in, see if it goes up and down when you turn the engine by hand, then repeat for the other cylinders (make sure the rod is long enough not to lose it in the cylinder). Then do a leakdown check by filling the cylinders with oil and seeing if it's still there in the morning - don't try to start it with the bores still full of oil though. Neither of these will definitively tell you if there is compression or not, but if it fails either check, you know you've got problems.
Does seem a bit strange that it's not even having a go at starting on any cylinders though
Link to comment
mark, I wouldn't mess with the car. I'd take it (trailer it by RAC or whoever) to a dealer for a proper evaluation. Don't fill the cylinders with oil either. Not recommended to do a leak down at this point, and it's not needed. Compression test at the dealer will tell all you need to know and they need to do some other tests. It won't start most likely due to the ecu shutting down the engine due to detecting the engine running too hot without oil. It needs resetting. But don't touch it. Is the car under warranty? It won't be a warranty job if something has forced it's way into the engine, but if something forced it's way out, different story. So are you sure about that? Do keep posting on this if you will.
Link to comment
Thanks for all the replies.
I have a compression tester, but typically it won't fit down the 3 mile tube to reach the cylinder head! Ruddy modern engines.
Estate Man-
That's interesting. I had a feeling there might be a "catastrophe protection" mode that have activated when the oil pressure dropped to critical levels. I disconnected the battery in the hope that might reset the ECU, but it may be there is a software switch that needs to be reset.
I don't usually drive it so am unsure about the normal state of the dash lights, but I note that the "EPC" light is illuminated when the ignition is turned on and does not go out even when the engine is cranked. So that  could well reinforce your suggestion that it's now in a "don't start me" mode.
I'm not generally keen on taking cars to dealers and do most repairs myself, partly because I'm tight and partly because I quite like doing it. Anybody know if this is a DIY fix?
Many thanks again for all the input
Link to comment
Look for members near you with VCDS and read stored codes.
Whereabouts are you?
I'd be tempted to buy a compression tester with a longer 'hose', if you want to carry on DIY. Pretty cheap in the grand scheme of things.
Link to comment
I'm near Sevenoaks in Kent.
Having poked about in some other forums, it may be that I did not disconnect the battery for long enough (31mins is I think the magic number) so I'll try that next and see what happens.
Link to comment
there won't be any safety cut out due to oil pressure, it will run till it dies! I would have thought replacement engines if required could be picked up quite cheeply
Hi Mark, does your daughter know how long the engine was run after the oil light came on?
Link to comment
I tried disconnecting the battery for an hour to see if the ECU would reset, but no luck. The EPC dash light is still illuminated whjen the ignition is on.
@warrior193
She was actually at the top of a hill and coasted in neutral to the bottom, whereupon the engine had stopped. Maybe 30secs?
Edited by markb
Link to comment
@warrior193
So possibly not terminal on the main bearings, you might be lucky. Given the circumstances, I rather doubt that too much damage will have been done - did the engine shut down by itself when the oil light came on, or did she turn it off?
Link to comment
@warrior193
I can't be sure because a) she was in a bit of a state, and b) she's now in Thailand.....
I have a sneaking feeling that there is an ECU related reason that it won't start. The presence of the EPC dash light nags at me.
Link to comment
With no faults logged the EPC light will probably not extinguish until the engine has started and is idling. Any fault codes will be in non-volatile memory and will need a diagnostics tool to reset.
If I was in your shoes I would take a punt on a new sump and gasket and a gallon of 5W30 and then put a shout out on the VW, SEAT and Skoda forums for a local with a copy of VCDS to do the diagnostics for some beer tokens.
Edited by ronime
Link to comment
@ronime
I've done the cheapskate's version of a new sump by plugging the hole with good old Plastic Padding, so it's refilled with oil (no leaks as yet) and ready for a willing diagnoser to raise their hand!
Edited by markb
Link to comment
Maybe you need to check the engine timing incase the tensioner has dropped back with lack of oil pressure and has allowed the chain to jump a tooth or two?
Link to comment
I think the Citigo uses the 3 cylinder version of the EA211 which uses a belt to drive the camshaft
Edited by bigjohn
Link to comment
Unlikely to be piston rings as bores have a lot of splash lubrication from the crank turning. On a non turbo car usually the first things to be damaged by oil starvation are the crank shaft bearings - especially the big end bearings. If not seized engine would still run but make a lot of of noise as the oil gets hot and thinner
If you get it going the sump will require changing - that temporary repair will fail in time with heat expansion/contraction
Any codes logged?
Edited by bigjohn
Link to comment
@bigjohn
I haven't got a VCDS lead anymore so haven't yet been able to check any fault codes. I could well be barking up the wrong tree, but the presence of the ECT light makes me think that the ECU is preventing it from starting. The bodge to the sump was just temporary to see if it had seized. I agree, it will need replacing if the car is worth salvaging
Link to comment
@bigjohn
Hi - Do you mean EPC light doesn't go out(as you mentioned further up the thread) - If so this is normal , this remains illuminated until the engine starts
Link to comment
Aah. So I am indeed probably up the wrong tree. I think a friendly VCDS owner is my best shot at diagnosing.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
