19mm ARB to 22mm ARB Upgrade
Recommended Posts
ARB upgrade
PRO:
- better car handling in corners on uneven terrain
AGAINST:
- stiffer suspension, you will feel every bump of the road
- another suspension item that needs maintenance
Is it worth getting new bushes and, if so, is it worth polly bushing it?
http://thebushingking.com/bushings-better-polyurethane-rubber/
Link to comment
Share on other sites
If you have a a 19mm one on car then you can reuse the ones on the arms but be carefull as they tend to snap when undoing remove the rust and spray with some kind off penatrating oil and the ones on the cross member need to be 22mm rubber bush's metal brackets the same you need to remove gear selector rods and exaust to fit the anti roll bar... poly bush's will be expensive in the UK as there not really a sort after bushs
  • Like 1
Link to comment
I would recommend the ARB upgrade to anyone considering it. But note, the bushes on the bigger ARB were considerably better condition than the previous ones and so it may be also attributable to that. Combined with new coilovers and top mounts there is a huge improvement.
Also have my old ARB if anyone wants it?
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
