312mm brakes - Pictorial
Tech1e
Recommended Posts
Hi there, im new to all this so 1st of all, hello to everyone.
Quick question just had my fabia vrs re-mapped, now thinking bigger brakes, these 312mm brake, do they fit straight on with the original calipers or do the calipers need modding?
Link to comment
Share on other sites
Truly amazing guide:thumbup:
Do you have any recommendation on where to buy cheap 312mm caliper carriers?
I am looking to fit those 312 discs to my octy elegance 1.8t with 288mm ones.
Link to comment
Can anyone help. Will this 7mm allen key head be long enough to to get in and undo the 7mm bolts ????????????
should be ok , but the more worn the pads are , the longer the 7mm tip needs to be , so if the pads are well worn you may struggle to get the socket into the rubber boot
Link to comment
cheers. pads are half worn, but getting replaced. so should be good. only really need that 7mm socket for doing it up to the correct torque setting.
Link to comment
  • 11 months later...
Get my 312's and a pressure bleeder next week.
The guide is excellent. All that remains is; can someone advise the tightening torque for the 18mm carrier bolts and the 7mm allen key sliders?
Thanks.
Link to comment
  • 2 months later...
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
