312mm brakes - Pictorial
Tech1e
Recommended Posts
And to further expand this 312mm thread to non vRS owners
To run bigger brakes you will need
o/s bearing housing 6Q0 407 255 S 114.38+vat
n/s bearing housing 6Q0 407 256 S 114.38+vat
wheel bearing x 2 6R0 407 621 A 87.72+vat each.
Thank you, thank you, thank you! B)
Link to comment
Share on other sites
Though is it worth the £720approx to complete?
Not at the moment, but it might be in the next 6 to 12 months... :) Funds and other circumstances permitting. Very good point though.
Edited by Leodhasach
Link to comment
  • 1 year later...
There's a octavia vrs just turned up at a local scrap yard if I go buy the front disks and calipers and carriers is there anything else I need for a swap to my fabia vrs
Link to comment
  • 3 months later...
Just pump the brake pedal but only go half way down, should be fine and yes the brakes fit under those wheels.
Having changed the brakes yesterday and not having access to a pressure bleeder, myself and my brother did the old 2 man, brake fluid in a jar trick but i hadn't read about only pushing the pedal half way, so therefore pushed fully. Is it likely i could have damaged the master cylinder??
Having driven over 150 miles since doing it, every feels fine at the moment.
Link to comment
  • 2 months later...
  • 5 weeks later...
  • 4 months later...
Hi guys, just bringing an old thread back to life here as I need a new set of Zimmerman discs and can't remember anything about them. Does anyone have a part number for the drilled/grooved discs that go with the 312 brake set. I have one of the sets from golfturbo that I acquired many years ago. I think they came from an Audi TT and that's all I can remember! Thanks if anyone can help. :)
Link to comment
  • 3 months later...
Thats the two different types of caliper as per the first post. The original on the left doesnt have the 7mm allen key bolts. The one on the right does. the 7mm allen keys 'sliders' mount the caliper to the carrier. the original bolts mount the carrier to the bearing housing.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
