Octavia: Useful part numbers for Octavia DIY servicing and mods
Recommended Posts
Mr Haynes says you need a 256mm disk 22mm thick. min thickness is 19mm
hth
billy
Thanks a lot billy, can you adice which is the best brand to go with?, preferably one with less noise and less susceptable to brake fade.
Link to comment
Share on other sites
Im looking a code for MAP sensor for my 2003 vrs 1,8t AUQ engine. Im getting 16622 code :(
So, does anyone know will 0 281 002 401 (038906051C) map sensor work on my car? Map that is in place right now has a code 038 906 051. Only difference is the C letter :dull:
Edited by Osku_P
Link to comment
Phone your nearest dealer and give them your registration number and they will sell you exactly the right part. Those two part numbers may be the same part but an extra letter has been added as a revision at some point.
Edited by chicken_eyebrow
Link to comment
038 906 051 is the right one. (Possible with A letter after code) When there is C letter after number code its for diesel engines (3,0 bar). Original is 2,5 Bar. 3,0 Bar Map sensor will fit with litlle modifications with sealing and work. But this gives a possibility of a overboost becauce ECU sees a lover boost levels than actually there is. With remapped cars this is not a good idea. In here 2,5Bar sensor is 2 times more expensive than the 3,0 Bar sensor. This info I got from a local dealer. I ordered the original 2,5 Bar :rofl:
  • Like 1
Link to comment
  • 4 weeks later...
Warning light (ie modified hazard warning light/indicator relay)
1U0 953 235E 300 - £28.36
whats different on this????????????
also are these only on wrc???????
Front Suspension Braces
8L9 805 629 A Upper strut brace £48.60
8N0 199 403 B Lower brace £13.20
N 104 679 01 Bolts for lower brace 2x£1.14
  • Like 1
Link to comment
  • 2 months later...
Some new PN's:
Front ARB Droplinks (RS):
1J0411315D £25.33+ VAT
1J0411316D £21.96+ VAT
Rear brake lines from flexy pipe joining rear beam to caliper:
1J0611763AD new version: 13.23 + VAT
1J0611764AD new version: 13.23 + VAT
  • Like 1
Link to comment
Skoda OE part numbers
Switch - brake light (common to all models)
1C0 945 511 A RDW - £7.76
(latest modified switch - green)
Now £10.15 including VAT, HTH
Link to comment
Clutch pedal (prices March 2011, excluding VAT, from VW TPS)
1J2721319C Pedal clutch £20.20
1H0721357 Mounting £ 0.68
1J2721332A Stop for switch £ 2.01
1J2721232A Stop £ 0.79
Link to comment
oil pump 06A 115 105 B £108.11
rocker gasket 058 198 025 A £19.63
front bumper 1U0 807 221 G £153.12
rear bumper 1U9 807 421 F £160.14
  • Like 1
Link to comment
  • 4 weeks later...
hi all new to the skoda owners club having just purchased a vrs octavia just wondering if there was any useful sites to get stylish accessories for my car??
Hi Will-i-am
Have you thought about using some hammerite or trading it in for a new Fabia VRS
:rofl:
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
