Falken FK-452's
ScoobyChris
Recommended Posts
Yeah they have been balanced, but not very well! so going back to get them re balanced. Just to add i got them fitted at a small independent tyre garage so bit surprised they need re doing. All the threads i have seen say the 452's are quiet! im starting to think may be there's a fault with one or both tyres?! ?
Link to comment
Share on other sites
Just had another thought about this! probaly wrong but anyhow.. the tyres are rotation tyres and are pointing the right way, but do these tyres have an outside/inside edge? Reason i ask is they have some coloured dots on them red/yellow and green i think, one tyre is showing this on the outside the other is in the inside? I would of thought they should be the same with the dots on the outside showing. But having just said that it does not say outside egde on them!
Link to comment
The coloured dots indicate the point of lightest weight, and maximum runout etc, and will be used as a guide by a good tyre fitter, showing him where to fit the tyre in relation to the valve and to the wheel itself.
For a full explanation have a look at Car Bibles : The Wheel and Tyre Bible Page 1 of 2 - an excellent site with lots of useful information.
To quote from the site (with probably more info than you will ever need).....
Coloured dots and stripes - whats that all about?
When you're looking for new tyres, you'll often see some coloured dots on the tyre sidewall, and bands of colour in the tread. These are all here for a reason, but it's more for the tyre fitter than for your benefit.
The dots on the sidewall typically denote unformity and weight. It's impossible to manufacture a tyre which is perfectly balanced and perfectly manufactured in the belts. As a result, all tyres have a point on the tread which is lighter than the rest of the tyre - a thin spot if you like. It's fractional - you'd never notice it unless you used tyre manufacturing equipment to find it, but its there. When the tyre is manufactured, this point is found and a coloured dot is put on the sidewall of the tyre corresponding to the light spot. Typically this is a yellow dot (although some manufacturers use different colours just to confuse us) and is known as the weight mark. Typically the yellow dot should end up aligned to the valve stem on your wheel and tyre combo. This is because you can help minimize the amount of weight needed to balance the tyre and wheel combo by mounting the tire so that its light point is matched up with the wheel's heavy balance point. Every wheel has a valve stem which cannot be moved so that is considered to be the heavy balance point for the wheel.
As well as not being able to manufacture perfectly weighted tyres, it's also nearly impossible to make a tyre which is perfectly circular. By perfectly circular, I mean down to some nauseating number of decimal places. Again, you'd be hard pushed to actually be able to tell that a tyre wasn't round without specialist equipment. Every tyre has a high and a low spot, the difference of which is called radial runout. Using sophisticated computer analysis, tyre manufacturers spin each tyre and look for the 'wobble' in the tyre at certain RPMs. It's all about harmonic frequency (you know - the frequency at which something vibrates, like the Tacoma Narrows bridge collapse). Where the first harmonic curve from the tyre wobble hits its high point, that's where the tyre's high spot is. Manufacturers typically mark this point with a red dot on the tyre sidewall, although again, some tyres have no marks, and others use different colours. This is called the uniformity mark. Correspondingly, most wheel rims are also not 100% circular, and will have a notch or a dimple stamped into the wheel rim somewhere indicating their low point. It makes sense then, that the high point of the tyre should be matched with the low point of the wheel rim to balance out the radial runout.
Link to comment
Yeah cheers mate, after i posted that i found that website myself very interesting!
Well went back to the garage today where i had them fitted (could'nt wait till weekend car felt **** to drive with wheel wobble) and got them re balanced! They where a long way out but in fairness to the garage felt ok when first fitted. The guy reckons this is quiet common when the start to seat in, but im abit shocked by this as it's only been two days. Seems alot better at the moment but still more road nosie then the conti's. Need to rack up a few more miles yet to scrub them in only done 200miles.
Link to comment
Well these have started to scrub in now and the grip is great, steering response is much improved too. But still not 100% happy due to the noise! The road noise is queit when on motorway etc it's just when coming to a stop there is aloud drowning nosie! (It's not the brakes) any ideas? have i got a faulty tyre?
Link to comment
  • 2 years later...
Cheers mate, yeah wheel bearings are being checked tomorrow, but this now seems like the most likely thing as i have swopped the wheels from back to front and the noise is still there.
had my fronts replaced with these about 6 months ago and just got 2 new ones on the rear. i to have noticed the road noise at low speed around 5mph down to 0 they make a droning sound like when you have a flat, thought it was the brakes or wheel bearing at first but i think its just the way they are, tried differant tyre presures which made no dfferance very good tyres though for the money
Link to comment
Holy thread revival! :o
I put the 452s in the mid-range of acceptable. Wasn't blown away by them when I tried them. For what I'm after, there's other alternatives at that price range.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
