The old hesitation after remap problem
Recommended Posts
How do we know that this behaviour is just the map. Has it done this since the word go?
Presumably engineers and software writers spend hundreds of hours on developing the original engine management software to iron out this sort of issue.
Link to comment
Share on other sites
I've found this for a remapped vRS;
It won't be the map. The map will only highlight problems early due to everything being optimised. Sounds like possibly an air mass issue!
To me it feels like turbo surge? So the DV or N75 would be my guess... Might do the n75 first as it's cheaper!
Link to comment
Got my car back yesterday after a remap and have noticed a hestitation most noticable in forth and fifth. The car seems to hold back then surge then hold back again before returning to normal.
Mart
Mine has the exact same hesitation you have described, I noticed it about 2 hours into a 180 mile journey home after having a jabba custom remap done last thursday.
Jabba already replaced the N75 valve while they were doing the remap.
Today I have checked all around the pipe work etc (top and bottom) and cannot see any faults.
I'm expecting a Forge 007P to arrive in the next couple of days to replace the std Bosch DV.
I'll let you know if the 007P "does the trick".
bill
PS. I can see this getting expensive :rolleyes:
Link to comment
Mart
bill
Nice one we shall see what happens:thumbup:
I did a vag-com block 120 bhp/torque run last night and it came back at 237lb/ft of torque.I think this is quite high for a remap on standard car apart from exhaust. I wounder if this problem only affects cars with a high torque figure after a remap?
I am going to do a boost check with vag-com on the turbo when i find out how to, to see just how much pressure its under.
Link to comment
Mart and Ethos
I have now got the Forge 007P DV (fitted with a green spring - recommended by Awesome), and intend to fit it in the morning.
Also, I have made a (bench) pressure test rig that will enable me to test both the std DV and the 007P DV (at the same time), and record what pressure each valve is lifting at.
Over the last few days I have been putting a lot of thought into this hesitation problem, and think that the key to resolving it will come from understanding how the functioning of the std (OEM) boost pressure control valves are effected by the increase in boost pressure acting on them, over and above max design working pressure.
If the 007P fails to cure the problem, I intend to fit an adjustable high flow pressure regulating valve between the turbo outlet pipe and the N75 valve. This will enable me to operate the N75 valve, and the turbo waist gate actuator diaphram at OEM (std) max boost levels, without reducing actual max turbo boost level.
Hope the above makes sense to you.....will let you know outcome of the DV.
Link to comment
Mart, Ethos
Tested both DV's this morning on my home made test rig and got a suprise at the results.
The various tests I did showed the std (plastic, naff looking) bosch DV off my 17,000 mile, 53 plate vrs is actualy a decent bit of kit, and was as good at holding boost pressure as the new Forge 007P, (and on a couple of occasions was better).
However, maybe I missed something...... but the Forge DV does appear to be working well. backed up by the fact I've just got back from a 20 mile hesitation free white knuckle ride :D
So is a Forge 007P the answere ???? I'm not sure (yet), were off to Leeds tomorrow and will the give 007P better and longer test.
Link to comment
Just got back from a 120 mile round trip to Leeds, the car seemed to behave OK on the way there but about half way home it started hesitating again :mad: The hesitation occured in 5th gear at about 70 - 80mph.
Bit pi**ed off at the moment, looks like I just spent nearly a hundred quid on a Forge 007P DV for nothing.
The only good news is, I'm now reasonably confident that my hesitation problem is a direct result of an over enthusiastic waist gate actuator. The hesitation is occuring under max load and torque right at the point when the waist gate should be opening to control boost pressure.
This could be due to a faulty (new) N75 valve, but I think its more likely to be caused by the waist gate actuator opening to fast, to far and closing to slowly, due to the effect of twice OEM levels of boost pressure being applied to the waist gate actuator via the N75 valve.
As stated in my previous post, a 7 psi max pressure regulating valve will be going in the feed pipe to the N75 to try and restore normal control of the waist gate actuator.
This may take a few weeks to get the right regulator valve, but I'll let you know how I get on.
Link to comment
Hi Bill,
I read on the cupra forum that some members have had 3 new n75 valves just to get one that worked right. I also read that many members tried upgraded n75s and they thought it fixed the prob but a day or so later the hesitation was back.
Hope you get it sorted,you seem to know what your doing.
p.s
I have just bought a secondhand, known to work n75 (3000 miles of use) which should arrive soon i will see if this works for me.
Link to comment
Hi Mart
Good luck with the N75.... will look forward to hearing how it goes :thumbup:
Does sound like some N75's cope better than others on remaped cars.
It would be just my luck to get a duff one.
Link to comment
Ok;
I'm going to (hopefully on my lunch) refit my bosch standard DV to my car instead of the stratmosphere DV I have on at the moment to see if that makes any difference.
If it doesn't, I'm going to clean the throttle body (actually going to do this anyway).
If that doesn't make a different N75 :)
Just need to find out what size jubilee clips I need now! :)
Also the top pipe has melted a bit on the cover I think;
http://www.aoyt95.dsl.pipex.com/dv.jpg
Link to comment
I very much doubt the DV will make a difference.I put my new forge dv on not a bit of difference but i didnt think it would.I bought it to make sure the bosch one doesn't expire on me and the diaphram end up in the turbo:eek:.
My n75 is due any day now,i hope this will make the difference;).
Together we will beat this damn hesitation :thumbup:
Link to comment
Hmm, it shouldn't take me long to change over though and would be worth trying just incase. Can't do any harm? It was working when it came off!!
I had a "hoon" earlier on and it was getting pretty annoying, couldn't get a smooth run at all with the 3/4 throttle surge.
Oooh, new n75! Are you fitting it yourself?
Link to comment
I bought a known working secondhand n75 with 3000miles on it- £26.
The n75 is next to the dump valve with 3 small pipes comming out of it.
Your pipe has probally been rubbing on your engine cover.My dv is mounted in reverse position at moment as mine rubbed.
Link to comment
It's next the diverter valve... I thought it was near the throttle body at the front of the engine! Haven't actually looked for it.
I'm guessing it's not easy access?
I don't think that pipe has "gone through" so it wouldn't be that cause problems (air getting it).
Let me know how you get on when you get it, also some pics of you fitting it would be ace ;)
Link to comment
The n75 is shown in the pic you posted earlier.to the right of the dv with a electrical connector plugged into it.It looks like it has a jubilee clip on it.Has it already been replaced as they usually come with crimp clips on as standard?
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
