• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
BEEP - temperature red light
Sign in to follow this
Followers 0
17 posts in this topic
People,
Stupidly last night I didn't put my car away in the garage and left it out, got out to it this morning at a very cold and dark 6am to head off to work and it was frozen solid :( Staretd the engine and started to de-ice the windows on outside, once I got back in to the car i noticed the red thermostat type temperature gauge light was flashing at me (looks like a thermometer with some red lines next to it on left hand side of dash) Thought this was just due to it being cold and so turned it off and turned on again (the old if in doubt reset the PC and it works again method!) and it didn't come back on again, HOORAH! However, am a bit concerned that something is going / has gone wrong with the engine?
This happened before when I was on holiday up in Scotland in January this year and we had some snow, just put that down to the super cold weather and it wasn't used to it?! Again turned it off and on again and the light and beep didn't come on!
Can someone put my mind at rest please as I am a complete doooshbag when it comes to mechanics!!
Cheers,
Hicksy :thumbup:
Share this post
Link to post
Share on other sites
I guess it could be a fault with the sensor. On a recent thread I reported that I have just purchased a Fabia 1.4MPi for my wife and that has been exhibiting similar symptoms to those you describe. In this case, though, it's not necessarily the outside temperature that's causing it. The temperature warning light comes on when the car is pointing down a steep hill (sometimes it's when we switch the engine on while parked on a hill, other times it comes on when driving down a hill and hitting the brakes). In recent days it has started doing it when switching on the engine on a flat surface too. The actual temperature gaueg, though, reads just fine.
I have purchased some coolant and will top it up at the weekend. Will let you know if that sorts it. Otherwise, it could, indeed, be temperature-related, or it could be a faulty sensor.
Is the warning light supposed to warn that the temperature of te engine is too high, or does it indicate the coolant level is too low?
I hope somebody else can be more helpful, but thought I'd let you know that there is somebody else with a very similar issue.
Share this post
Link to post
[quote name='r_holmes22']Is the warning light supposed to warn that the temperature of te engine is too high, or does it indicate the coolant level is too low?quote]
I've got no idea :(
Just in case there's any confusion, it's not the friendly "beep" you get when temperature outside reaches below 4degress, it's the angry "BEEP" simialr to when you're running low of fuelage!!
Share this post
Link to post
my VRS has started doing this too, the car has always been parked facing down my steep drive and the prob has only started since the cold weather.
Turn the engine off and back on, light is gone. has happened on 3 mornings now.
Not too worried, but now you guys know its not just you.
Share this post
Link to post
I had the same problem when coming to a stop on a steep downhill.
Coolant level was around the minimum level on the expansion tank (when the car was on level ground).
Topping up to maximum with G12 antifreeze sorted it.
Share this post
Link to post
[quote name='vrshicksy']
.. once I got back in to the car i noticed the red thermostat type temperature gauge light was flashing at me (looks like a thermometer with some red lines next to it on left hand side of dash) Thought this was just due to it being cold and so turned it off and turned on again..
[/quote]
Ditto here.
It looks like a lot of us are experiencing it due to the cold weather. Haven't had chance to check anything over so far this week but I'm cleaning the car tomorrow so I'll have a poke around and see if I can spot anything that might cause it.
Share this post
Link to post
Good stuff, cheers guys! Looks like a top of anti freeze might sort the issue out then, glad it's nothing major - was starting to get worried!
Share this post
Link to post
[quote name='vrshicksy']Just in case there's any confusion, it's not the friendly "beep" you get when temperature outside reaches below 4degress, it's the angry "BEEP" simialr to when you're running low of fuelage!!
Cheers[/quote]
Not in mine. The low on feeding is a louder and angry beep, the "its cold outside innit" one is a friendlier, cool jazz piano style "ding", and the trip computer stays glued to the temp instead of where I left it - usually average MPG because I'm tight.
Share this post
Link to post
[quote name='vrshicksy']People,
Cheers,
Hicksy :thumbup:[/quote]you can actually fit your car in your garage? :rofl:
Share this post
Link to post
My Skoda does this every 250 miles orso and then I have to fill it up 0,7liters(sorry i'm a metric lad) G12 coolant.
I have a petrol 1.4Mpi Ive been to the dealer twice now first to replace the gasket on the thermostat(i think) 2nd for an overheating engine(fan failed)
I rang them up after they renewed the gasket and I had to refill the coolant.
The reply was that there was still air in the system, wich sounds fair.
This morning(after 250 miles from the fill up) I had to do that again.
I don't have any muck in the expansion tank, so the head gasket problem is out.
I've had a look around the engine and radiator but I see no leakage, I'm at a loss now.
This car is 6 years old now and has about 55k miles on it.
Does anybody have a clue?
Share this post
Link to post
If you read the manual it says the light you are all talking about beeps to indicate both low oil level and oil level temp . As such if the oil is too cold it will sound, wait until the temp increases, turn the ignition off then on again and the light will go off. i get this. Manual has the answer people...
Share this post
Link to post
[quote name='stuno1']
Manual has the answer people...[/quote]
Now that's just far too sensible.
I bet all your CDs are arranged alphabetically aren't they :rolleyes: :D
Share this post
Link to post
I know and at 24 as well! oh a sad life awaits!!!
Share this post
Link to post
[quote name='stuno1']Manual has the answer people...[/quote]
The manual is boring, there's no story line at all :D
Share this post
Link to post
[quote name='vrshicksy']The manual is boring, there's no story line at all :D[/quote]
ROFLMAO!!!
:rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl:
Share this post
Link to post
I don't know if it is all the same thing. I have a 1.6 Octavia and I have noticed that if the water is ever so slightly low that light comes on and most times you only need to add less than a cup of coolant/water. It might however indicate a leak in the cooling system. With mine it was what the garage called "water connector" mine has 2 an inner one and the outer one I guess
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
