2003 Skoda Fabia 1.2htp (55bhp) reversing lights not working
delh68
Recommended Posts
Hi all,
Have used the search facility, & have eliminated the fuse & the bulbs from being the problem ~ they are fine.
I have a 2003 Skoda Fabia 1.2 htp 55bhp classic
There is mention of a switch on the gearbox on previous threads, but i have had a look & all i can see is a sort of spring contraption that moves when reverse is engaged.(no sign of a switch at all:()
Anyone with any opinions?
Delh68
Link to comment
Share on other sites
there will be a plug and switch somewhere on the gearbox for the reverse lights , when you find it , disconnect the plug and bridge the 2 connectors in the plug with a paper clip , make sure it doesn't touch anything metal , then turn the ignition on , if the lights now work , its deffo the switch which is faulty
Link to comment
Thanks ~ i'll have a good look when it's daylight
Delh68
Link to comment
The switch should be on the front of the gearbox casing
Being a bit useless with cars:eek: (bit willing to have a go!)~ would that be under the car / bonnet or inside??
Thanks for everyones' replies
Once this is sorted i've got to do my rear door seals (leaking), & the front passenger side seat belt (not retracting)
Delh68
Link to comment
under the bonnet, but it maybe only accessible from underneath with the undertray off (if fitted)
seat belt not retracting could be from the water ingress from the rear doors , the belt swells up slightly when damp and is then slow to retract
Link to comment
If it stays dry, i'll have a look tomorrow:)
Thanks for the useful information
Delh68
Link to comment
Finally got round to having a look at this ~ the wires have sheared off right at the base of the plug, so i'm going to have to do some re-wiring :( & get some bits from the dealership when they re-open
Delh68
Link to comment
Delh68
All sorted for the princely sum of £4 (new plug & cable) from the local VW dealer:P
(Although i did end up buying a reversing ligh switch for £9 as well, as i thought it was that at first!
Thanks to everyone for your help
Delh68
Link to comment
  • 2 years later...
Hi, I have the same problem but cant find the location of the reverse light switch,
I have already bought the replacement part and have even lifted the car up and even removed the gear stick damask I cant fint the location of the switch please help me!
Link to comment
Side of the gearbox, just below the gear change selector assembly.
Link to comment
  • 2 years later...
Hi guys very useful website and has helped me so much, I'm having the same problem with the reverse light.. It suddenly stopped along with the brake lights but the brake switch I fiddled a bit and managed to get 2/3 lights working.. So I'm useless with cars! Any help with the reverse lights in detail because I didn't understand much above. Where shall I start?
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
