- Version 1.0.0
- 335 downloads
Skoda Karoq - Engine code: CHZD.
Contents: Spray-ignition three-cylinder engine 1.0l TSI 85kW, Engine technical data, engine technical data for the engine, Modular engine construction, TSI engine, Modular construction of the three-cylinder engine, Engine in-line engine, Engine intake system, Cylinder mechanism, Aluminum cylinder block , Vibration damper and flywheel, Vibration damper fittings, Cylinder head, Mixture preparation, Continuous oil pressure regulation, Rotary vane oil pump,
