build spec
I have used seller glavanesti on eBay a number of times to buy full VIN decodes (ie build specifications) for VAG cars in my family. The price is €3 and the details are provided very promptly by email.
Coding A Yuasa Battery Using Carista - Anyone Ever Done It?
Yes.
I bought and recoded the same replacement battery for my 2015 Fabia 3 last year. Change 59 to 65 and 1111111111 to 1111111112. Leave EFB and JCB unchanged.
Front light lens replacement
I own a 2016 Fabia 1.2TSI SE L with the same headlight and discovered a hairline crack from top to bottom after investigating the source of excessive condensation inside the unit. Mammoth clear weatherproof tape stopped the leak and the car passed an MOT without any comment on that temporaryrepair. I am about to sell the Fabia and decided to replace the headlight before doing so. The part number is as above - 6V2.941.016.B - and is made by Hella. I have the old unit and can confirm that lens is not replaceable separately. I had the replacement done by an Independent VAG specialist. The part was sourced from TPS and cost £382 while labour including headlight realignment was £96.
Fabia Spare Wheel
My understanding is that you will need to buy an identical alloy wheel and tyre size if you don't want to be subject to speed and distance restrictions in the event of a puncture.
- Is there a list of trusted service dealers by area around?
Fabia Mk2 - Armrest Install
The one in the first post? There is currently one for sale on eBay.
Yeti 2013 1.2 auto DSG failure
This excellent link posted by another member might be useful reading for you. https://www.asrgearboxrepairs.co.uk/dsg-7-speed-gearbox-problems/
1.2 TSI Yeti - any advice appreciated on Yeti warning lights
Tanya are very competitive for batteries and deliver next day. Their price for the Yuasa YBX5027 is £81.21. I recently changed my Yeti batttery and it is easy to DIY, with no coding required if you car doesn't have stop-start. PS I didn't need to cut the cloth insulation.
Engine dies when horn used
My 2015 Yeti doesn't have stop-start so no coding was required when I replaced the battery last year. However my wife's 2016 Fabia does have stop-start and the recent new battery did need coding.
What's your Vehicle Score?
943 for my 2015 Yeti 1.2TSI Outdoor. Without doubt one of the best cars I have. owned.
Problems, problems after battery change - Kodiaq 2018 5-seater 20 TSi 4x4
Shouldn't the new battery have been coded differently to the old one, eg 1111111112, to let the system know it has been changed?
Timing chain cover date
On my 2002 Octavia 1.8T 4x4 the engine build date was 4 weeks before the car build date. I think my 2007 Fabia vRS was the same.
Petrol engine but sounding like a diesel?
From the OP's first post on Briskoda the car is a Skoda Octavia 1.5 TSI ACT SE DSG Euro 6.
Engine 1.8l TSI CDAA won't start after spark plug change
Have you read the first thread in this forum which is about timing chain failures? On page 7 you will see information on the fault codes which could indicate that this is the problem affecting your engine.
