Hi As per my other post (above/below?) I have a broken front coil spring. Haynes say I have to partly dismantle the lower arm & take the damper out of the hub to change the spring but I thought I read on here that you can do it just by disconnecting the top mount. I searched but I can't find that post. Was I mistaken? I want to find out before I start the job because I'm wondering whether to replace the dampers at the same time. If I have to remove the dampers anyway, I might just buy
