esp/abs and tyre light warning
DCL
ESP/ABS and Tyre warning light  comes on every morning on my 09 VRS and then goes off after approx 10mins, stays off rest of the day, even after being on stop approx. 4 hrs then it comes back  on next morning, this has happened over last 5 days. Any help on this matter would be gratefull.
Sensor fault usually clears below 30mph and reappears as you speed up. Teves fault doesn't clear at all.
This sounds like something else, I think a scan is your first port of call.
Scan revealed faulty sensor on rear wheel this was changed but warning light still failed to go out, Skoda then went looking for wiring fault,  eventually traced to main loom where a broken wire was found, very expensive fix as this took some time. Is it normal for wires to break in the main loom or can they heat up and snap ?.
