parts
BRISKODA Parts ( Genuine SKODA Dealer Parts ) + Other marques
105 posts in this topic
Apologies Dave I have replied.
Please don't be afraid to call me guys 01905 346808 you'll get a much quicker answer! I am very stretched! :)
Mike
Share this post
Link to post
Share on other sites
Mike
Got it thanks. Will give it some thought, cheers
Share this post
Link to post
Cheers, rang Mike 01905 346808 and discussed an d purchased at reasonable prices. Thanks Mike :-)
1 person likes this
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
    No registered users viewing this page.
  • Similar Content
    • By badger89
      WILL CONSIDER NEAREST OFFERS ON ALL PARTS (UNLESS STATED)
      Engine / Transmission
      - MAF - Ibiza/Fabia/Polo = £15
      - 02M Long Ratio Gearbox - Ibiza/Fabia/Polo = £150
      - 6 Speed Cables - Ibiza/Fabia/Polo = £20
      - Driverside Driveshaft - Ibiza/Fabia/Polo = £20
      - 90A Alternator - Ibiza/Fabia/Polo = £20
      - Aircon Compressor (6Q0 820 803 D) = £20
      - N75 Module (6Q0 906 625) = £15
      - Fuel Tank Sender - Ibiza/Fabia/Polo = £20
      - PD130 Inlet - Ibiza/Fabia/Polo = £20
      Wheels / Suspension / Steering
      - Steering Rack = £25
      - Steering Angle Sensor + Wiring - Ibiza/Fabia/Polo = £25
      - Both Above Complete = £40
      - ABS Pump - Ibiza/Fabia/Polo = £25
      Body / Trim / Electrical
      - Heater Motor (6Q2 820 015 C) - Ibiza/Fabia/Polo = £20
      - Ibiza Fog Lights = £10
      - Comfort Convenience Module (6Q1) = £15
      - Electric Window Motor Passenger = £15
      - Electric Window Motor Driver = £15
      - Accelerator Pedal (281 002 374) = £15
      - Front Wiper Motor (6Q2 955 119 A) = £15
      PM me if you're interested and if there is something that's not listed!
      Also these parts are advertised elsewhere so I will update as I go.
      I'm located in Newcastle-under-Lyme, ST5
    • By mikey200615
      Few bits and bobs for sale, all used but in good condition unless other wise stated.
      x20 extended wheel bolts (40mm thread) £15 posted
      x20 standard wheel bolts (26mm thread) £14 posted
      Abs pump £15 posted
      Fuel cap in black, black magic (has 2 deep scratches) £5 posted
      Fuel cooler £15 posted
      Nsr light cluster £15 posted
      3x pedal covers (rubber bit worn on accelerator pedal) £15 posted
      Indicator stalk £9 posted
      Rear seatbelts x2 £9 each, posted
      Rear door wiring looms x2 £10 each, posted
      Bonnet catch / latch and sensor £8.50 posted
      Standard dog bone mount £15 posted
      Gearbox mount £15 posted
      Rear exhaust silencer mounts £5each posted
      Servo £16 posted
      Brake master cylinder with reservoir £15 posted
      Full set of vac pipes £10 posted
      Clutch line £10 posted
      Coolant pipes £ 10 each, posted
      Alarm siren £8 posted
      Securing bolt for spare wheel £5 posted
      Steering column (no barrel or keys) £20 posted
      MAP sensor £8 posted
      Tail gate struts x2 £10 posted
      Check straps £10 each, posted
      Window winders £5 each, posted
      Clutch pedal spring £5 posted
      Drivers door lock and ignition barrel with keys (no fobs) £15 posted
    • By EoinVrs
      Hello
      had heard that is possible to get add on exterior parts for the mk1 octavia vrs, i already have the lower front splitter fitted to my vrs but was wondering is there more exterior parts i could add?
      Any links or ideas would be greatly appreciated
    • By chrisbowden
      Hi all,
      Looking for a bootlid for a Favorit in useable condition. It has to be a reasonable distance to collect from, I am located in Kent.
      Thanks.
    • By MattEds
      Hi all, I'm new to the forum as a poster so apologies if this isn't the right place for this question. So, my wife has managed (still not sure how) to rip out the passenger sun visor of our 2015 Octavia Estate. The clip that holds it in has broken down the middle and left half attached to the roof and half attached to the now detached sun visor. I have looked around for replacements of the clip but can't see anything on parts sites etc. It is the bit that fastens it to the roof (and allows it to swivel and twist) rather that the clip that you can attach and detach to move it. Hope that makes sense, and if anyone can help me out that would be great.
