Workshop warning message flash up
Twice on my drive to work over the last month or two (most recent was yesterday), I have heard a beep/boing sound, and then I have glanced down at the dash when safe to do so (normally a few seconds later) I have spotted the message '(check?) Workshop..... <something>' on the display, along with the yellow warning hazard triangle.
Sadly the message seems to vanish before I have had a chance to read it fully - much more quickly than than the 'ice warning' etc messages.  I've checked on the headunit and not seen any messages, other than one saying the Road Sign detection is limited (get a beep and a warning a few minutes after every time I start the start the car).  I was about 35 minutes into the trip, probably travelling at about 50mph on a straight-ish piece of road at a slight uphill gradient.
Will try and connect up VCDS later and see if that can tell me anything.  But in the mean does thing ring any bells?
Not sure on the current Octy but on the Golf the wipers do not clean the screen in front of the camera - so have you checked that the screen is properly clean.
Gave the car a wash at the weekend, so the screen is pretty clean.  That reminds me, must go and scan the car!
I suspect the last 2 detailed ones are caused by me enabling the Lane Assist camera for Speed sign detection.  Prior to that, however someone drove into my front offside wheel (20 Feb) so hard they broke the hub, so various parts were replaced by the insurance company, not sure if any of that would have a knock on affect.
Scan overview:
Tuesday,04,April,2017,13:55:26:35356
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170220 DS267.3
www.Ross-Tech.com
Chassis Type: NE (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F A5 A9
VIN: TMBKK7NE9F0035273   Mileage: 107481km-66785miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: OK 0000
Breakdown:
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 041 Q    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H52 4504
   Revision: 05852204    Serial number: TFK01406052109
   Coding: 0014
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021.rod
   VCID: 26447A13596D1171B3-8072
1 Fault Found:
10763 - Starter Enable from Selector Lever Sensor System
          P1734 00 [002] - -
          Intermittent - Not Confirmed - Tested Since Memory Clear
Address 16: Steering wheel (J527)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 DF    HW: 5Q0 953 549 C
   Component: Lenks. Modul  002 0110
   Revision: --------    Serial number: 18061404220906
   Coding: 1410
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_SMLSKLOMQB 017001
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 7DF6757FEC7B72A982-8028
1 Fault Found:
617752 - Selector Lever Park Position Lock Switch
          B1162 29 [024] - Signal Implausible
          Intermittent - Confirmed - Not Tested Since Memory Clear
Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 242
                    Mileage: 106002 km
                    Date: 2017.03.16
                    Time: 06:18:12
                    Operating time: 122652 min
                    Supply voltage: Terminal 30: 14.5 V
                    Vehicle speed: 88 km/h
                    Voltage at switch: 4.98 V
                    Terminal 15 status: active
                    System status: 30
Address 19: CAN Gateway (J533)       Labels: 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1188
   Revision: --------    Serial number: 0002172286
   Coding: 030100040F087300EF00026A1C0F00010001050000000000000000000000
   Shop #: WSC 73430 790 00000
   ASAM Dataset: EV_GatewLear 011016
   ROD: EV_GatewLear_011.rod
   VCID: 428CC683D505CD51BF-8016
   Alternator:
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 5E0 919 719 B    HW: 5E0 919 719 B
   Component: E221__MFL-PR6  H04 0130
   Serial number: 000000000C1890130614
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
   Component: J367-BDMHella  H03 8043
   Serial number: 8633583603
1 Fault Found:
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          Intermittent - Confirmed - Tested Since Memory Clear
 Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 3
                    Reset counter: 239
                    Mileage: 105294 km
                    Date: 2017.03.02
                    Time: 17:41:02
                    Supply voltage: Terminal 30: 12.4 V
                    Terminal 15: OFF
Address 5F: Information Electr. (J794)       Labels: 5E0-035-MIB-STD1.clb
   Part No SW: 5E0 035 874 A    HW: 5E0 035 874 A
   Component: MU-S-ND-ER    041 0435
   Serial number: S7F02606140248
   Coding: 03735201FF0000001111120100A800002F0001860100010046
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_MUStd4CPASE 002039
   ROD: EV_MUStd4CPASE_AU37.rod
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 5E0 919 605 D    HW: 5E0 919 605 D
   Component: ABT_Std_Nav  H60 0030
   Serial number: SKZ8Z9PT3001Q9
   Data medium:
   Subsystem 2 - Part No SW: 5E0 051 236     HW: -----------
   Component:  ECE 2016/17  --- 0059
   Serial number: --------------------
1 Fault Found:
7201 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 210
                    Mileage: 105204 km
                    Date: 2017.03.02
                    Time: 12:27:23
                    Voltage terminal 30: 12.1 V
                    BAP-BAP_Function_ID: 02
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0052
   Serial number: 10000098834
   Coding: 0101000001030304000400000000010100
   Shop #: WSC 73430 790 12345
   ASAM Dataset: EV_MFKBoschAU370 001001
   ROD: EV_MFKBoschAU370.rod
   VCID: 3B72BB67B2EFBC99FC-806E
1 Fault Found:
6553600 - Databus
          U1123 00 [008] - Received Error Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 10
                    Reset counter: 205
                    Mileage: 104811 km
                    Date: 2017.02.24
                    Time: 16:25:18
                    Control Module temperature: 26 °C
                    Outside air temperature: 10.0 °C
                    Vehicle speed: 1.92 km/h
                    Voltage terminal 15: 14.2 V
                    System run time: 67.0 s
Edited by mbames
Ive had the same error flash on my car. Took it to the workshop and they have diagnosed it as a defect in the selector lever. Part has been ordered and will only know if that sorts out the problem.
Meanwhile, did you get yours sorted? And if yes, what was the solution? Anyone else know about this?
Phew. I thought it was just me having this issue.
My 2014 vRS DSG does this about once a week, and the garage say there is nothing on the logs. I have to take it straight to the garage when it happens, so they can check the logs.
i'm about a month from my warranty ending, so am keen to understand the problem before my warranty runs out!
mbarnes, did you get any result?
@mbames @SnailUK
Does the error message say:
"Error workshop leave vehicle only when selector lever is in position P" ?
If so, you need a replacement gear selector lever. Just had mine replaced under warranty with two weeks left.
See here also as you will need to persuade the dealer to act even if they cannot find a fault code!
http://www.golfmk7.com/forums/showthread.php?t=18199&page=4
Good luck & please give me a shout if your dealer isn't playing ball. Mine needed a decent 'shove' before they agreed to change the selector lever!
Edited by dunc69
  • Like 2
That is the message..... Sadly my warranty is expired (in terms of distance), and it is very close on age now too :-(
Which dealer did you use?  I've used Westover/Heritage (Yeovil) but they not sure I have much faith in them sorting this out under warranty, or even attempting to....
Edited by mbames
15 hours ago, dunc69 said:
@mbames @SnailUK
I have the same problem and still waiting from 2 stealers to do something about it, I even made a video for them.
Blade Skoda Bristol. They said there is a bulletin about this issue.
Good luck getting it sorted!
My dealer initially said that he couldn't find an error & said I'd need to come back if the error message reoccurred.
I said, "Are you saying you don't believe me? Why else would I have brought the car to you? We are just going to end up going round in circles......I bring it in, you don't find an error, I go away....."
I then suggested I would take it up with Skoda UK.
Within 10 mins I had a call back saying the master tech had found a relevant TPI.
New gear assembly ordered, fitted last week. No issues since.... fingers crossed.
I might phone your Bristol based dealer and see what they say... and then get their tech to talk to Heritage  (Heritage already hate me when they had to to stump up for the water pump failure).
I've only seen the issue a couple of times - and curiously nothing since my post about it.....
I think the warning will come back.
Mine went quiet periodically and then would reappear, sometimes two or three times in very quick succession.
If you read the VW forum link I posted earlier, the general consensus is that the warning will eventually become more and more frequent.
I dealt with Abby on the service side at Blade.
Good luck!
Mine did become more frequent but later less frequent again, sometimes weeks without a error, then sometimes few error a weeks, no rules really. In either case it f*cking ****ing me off having such errors on a new car.
I was really "lucky" as mine happened yesterday, and i happened to be near the garage, so i drove straight there, got it straight on the computer, and now have it booked in for investigation, in the couple of days before my warranty runs out.
  • 4 months later...
I have this issue on my 2015 Octavia vrs tsi, the vehicle is under warranty. I take the car to the dealership and to investigate. The technician assures me that he has seen the issue before and confirms that it is the gear selector.
Anyway... they refuse to replace the gear selector as the message did not appear when the vehicle was with them. Better yet, they charge me £63.00 investigation fee, despite the car being under warranty.
Any ideas on how to tackle this?
There should be a fault code logged - query this with the dealer. Do you have a photo or video of the message showing on the car? If so this will help your case. Take it higher with the dealer and if there's no luck then take up with Skoda UK Customer Service.
  • 4 months later...
  • 6 months later...
Getting this error as well. After clearing its come to this below error. Strange it just popped up open. Car is about 1 year old. Happen to catch this on a normal full car scan. Don’t think this has anything to do with an audio install which uses a in line audio adaptor to the stock HU for DSP.
It's the selector lever. I had the same issue. Had it replaced and the car has been troublefree ever since.
The error is not showing anymore.. What exactly did you replace? Maybe this was a freak error.. Will have to keep a tab on it.. Even when the car was serviced at the Skoda workshop, there was 0 errors on this.
15 hours ago, z klasse said:
The error will flash and go away but will show in the log. So if all you hear is a beep, you can be sure it's the lever.
Let’s hope it stays away. I still have 3 years warranty left so no issues there.
  • 6 months later...
I had this problem, with the error message coming up intermittently.  I spoke to the dealership and booked it in, but the service manager said that if they couldn't identify the fault, they couldn't help.  Next time it came up, I stopped and took photographs of the error message.  Although the fault cleared, and wasn't showing when they tested the car, they accepted the photographs, and replaced the selector unit under warranty.
