EGR DELATING
22 minutes ago, lichfielddriver said:
I appreciate that but smoke/soot affects anyone with asthma, and instantly
I think the end is in sight for all diesels, HGV+PSV will have to convert to CNG
This thread is about EGR deletion, not DPF removal though.
Although EGR use creates more soot, the DPF will still catch it.
and soot up faster........i hear no reports of worsening DPF's after EGR deletion..
i want to see a proper NOX test of with EGR and then without before accepting this
58 minutes ago, langers2k said:
NOx reduction is the primary purpose of EGR... https://en.m.wikipedia.org/wiki/Exhaust_gas_recirculation
I have no doubt its the main purpose of it but where are the figures? and the figures after removing or blanking?
Years ago we were told catalyctic converters were going to clean our vehicles exhaust output after being imposed on US cars, what we werent told they were fine in California where they achieve operating temperature within minutes due to the big shiny thing in the sky baking the land, here on most trips in dark dank wet cold Blighty they just dont cut the mustard...
Don't forget your LNT (lean NOx trap). If you didnt have it then you could add SCR to your list and then you would have urea injection.
Then you really would be dirty because your emissions control would be having a wee in your exhaust.  :D
Edited by TheRobinK
Used a rude word.
There is a weakness on the CR140 EGR fitted to the MkII Superb, or at least there was within a certain production period.
Water ingress was the issue, and the costs to replace are exacerbated on the CR140 due to the difficulty in accessing the EGR.
I'm pretty sure my car (2011) falls within the builds that are more susceptible, so far its been OK - touch wood!
Quick google gave this paper:
https://www.researchgate.net/profile/Alagumurthi_Natarajan/publication/314600281_Effect_of_Exhaust_Gas_Recirculation_EGR_on_Performance_and_Emission_of_a_Compression_Ignition_Engine_with_Staged_Combustion_Insertion_of_Unburned_Hydrocarbon/links/58dca85d92851c611d3d33db/Effect-of-Exhaust-Gas-Recirculation-EGR-on-Performance-and-Emission-of-a-Compression-Ignition-Engine-with-Staged-Combustion-Insertion-of-Unburned-Hydrocarbon.pdf
Shows that it's possible to reduce NOx by over 50% using an EGR depending on engine load.
The downside is an increase of HC, CO and emissions opacity (due to increased soot/PM).
"Shows that it's possible to reduce NOx by over 50% using an EGR depending on engine load.
The downside is an increase of HC, CO and emissions opacity (due to increased soot/PM)."
To me that says "POSSIBLE" (and even then only at certain engine loading) to reduce NOX (I.E. Not certain) while the increase in soot IS certain, having had a Non-DPF car with an EGR I could see the soot...
If that was a court case/prosecution the CPS wouldnt let it go before a jury
Edited by lichfielddriver
Having to rely on ancient superstition now?
lol, dont walk under any ladders!
I have no idea what your point is anymore.
You appear to agree that EGR can reduce NOx although will increase soot so EGR removal will do the opposite.
Are you suggesting that EGR systems on diesels in the UK are so ineffective they do absolutely nothing to reduce NOx? What is your evidence to back up such a claim?
EGR valves increase soot -  as can be seen behind any Mk3 Tdci Mondeo... no EGR/no soot...
Wheres the evidence (actual not rhetoric or reports by funded bodies) that EGR blanking increases NOX?, actual tests. NOX can be easily measured (if you have the meter)...............
There is evidence in the paper I posted. It shows that for the majority of engine loads, running an EGR at 0% (effectively blanking it) increases NOx and decreases soot. You appear to agree with one of these findings (increased soot) but not the other (reduced NOx).
Out of curiosity, why do you think EGR valves are fitted assuming they have no effect on NOx.
Just now, usedabused said:
Who cares deleting the egr cleans up the intake charge resulting in better performance..
The OP might as they asked if EGR removal would change the cars emissions so they care. Anyone concerned with NOx and it's health implications should also care...
I have no issue with people removing or modifying emissions control devices but it should be done with at least a basic understanding of what the implications are.
I don't understand it, so it must be wrong...
Stick to driving cabs pal, leave the science of automotive emissions reduction to those who can get their heads around it.
