2007 skoda superb heating problem
Nig11
Do you have access to VCDS, if no personally then check on the map site to see who is local to you. Once you have found someone all it will cost is some tea/coffee as people are happy to help out. VCDS is the only way to find out what is wrong..
Edited by Danny 57
1 minute ago, SuperbTWM said:
If the car isn't showing any signs of overheating, its most likely to be a fault with the flap that mixes the hot and cold air.
Except heater failure can be the first indication of any problem with the cooling system (leak, water pump impellar etc..)  - Still worth checking as it's easyish to do
The mixer flap/servo  is difficult to get at!
