Resetting one touch windows
Tech1e
Recommended Posts
Should your vehicle lose its one touch setting follow these simple steps, same applies for each window.
Step 1. With the window in the fully up position pull and hold the window switch into the up position again, you should hear a small click from the motor.
One touch is now set for that window.
Have a nice day
R
  • Like 1
  • Thanks 1
Link to comment
Share on other sites
  • 8 months later...
  • 2 months later...
From the manual:-
"Turn the key in the lock of the drivers door into the closing position & hold it there until all of the windows are closed.
Release the key.
Insert the key again & turn it to the closing position for about 3 seconds."
  • Like 1
Link to comment
I dunno if i'm doing somthing wrong, or perhaps its just busted.
I had a similar problem, the drivers window would open all the way with one touch, but not close (even after doing both of the suggested 'resets') it now does work sometimes, if you pull the switch up very hard, possibly a worn switch?
Link to comment
  • 4 months later...
are you talking about one touch from the inside controls or one touch from the remote?
I tried what I've read here, didn't work, the remote still has to be pressed all the way in order for the windows to go up completely
Link to comment
  • 3 months later...
  • 2 months later...
I have a fabia ll purchased nov 2007 and my windows just started playing up.
I just have front electric windows. Faults as follows:-
Passenger side one touch not working.
passenger switch on drivers side not working at all but very occasional start to work and stop again.
Driver side one touch not working 90% of time.
Have tried all the reset techniques which seem to start driver one touch working but then stops again very quickly.
Have rung dealer and as I live a distance away am going to try and call in when in the area so they can put it on diagnostic machine.
Any ideas?
Link to comment
  • 4 weeks later...
My front passenger window will work one-touch up and down, but the drivers window will only work one-touch down, not up. I've tried the above reset procedure but without success. I'm not over concerned with it, but if anyone knows what the problem is I'd be grateful......
Link to comment
Could be dirty contacts on the switch board, I took mine apart and cleaned them and have fully functioning one touch up/down on both windows now for the first time since I owned the car :thumbup: Was a 10 minute job I can do a pic guide today if I get time.
Link to comment
Ok here is a guide to removing the window switches for cleaning. I have not shown the cleaning process as I had already done this before these pics where taken but it is simple enough to do.
Tools I used:
Large flat screwdriver, Small flat screwdriver, T7 torx driver, Philips screwdriver. Also electrical contact cleaner and a cotton bud.
Insert flat screwdriver here and prise out handle
As shown here
Insert screwdriver under handle surround and pop upwards to unclip the repeat other side until all clips are released.
Unplug wiring connect and remove handle assembly
What it looks like underneath. Remove 3 philips screw, 1 at top, 2 at bottom of switch housing.
Topview removed
Next remove the 7 T7 torx screws
removed
Locate the 4 retaining points on the casing and lever out with a small screwdriver
To reveal the board
Carefully lift out the board. The white pins below may stick to the silicon skin when it is removed, note their position and relocate them if this happens
Topview of circuit board with skin on
Carefully peel the skin off to expose top of board that needs cleaning
I smothered the board on both sides and skin on side shown in electrical contact cleaner and let dry
These S connectors are the contact points for the 1 touch and whilst the board was wet I used a cotton bud on these to give them a proper clean
Let everything dry completely before reassembley and installation.
Hope that helps with your one touch problems as it did mine :D
Link to comment
  • 1 year later...
lock car and immoboliser with remote control but leave front windows open
Shut the windows by inserting key in driving door lock turn cllockwise to close windows
One touch is now reset.
From the manual:-
Release the key.
I'm having no luck with these - seems like the problem is somewhat deeper. It was suggested I disconnect the battery and then try the resetting procedure - but I'm reluctant to do that in case something else goes wrong.
At one point the windows weren't working at all - then they were both working manually from their respective door switches - now the passenger door one's stopped working again...
Link to comment
  • 5 months later...
Have a nice day
R
Nice one mate, thats exactly the same process as the new jaguar/range rovers believe it or not :)
Link to comment
  • 2 months later...
The "hold the switch" didn't work for me.
The manual that came with my car - dated 05.05 - has different text to the downloadable PDF manual - dated 05-07:
My manual states:
Operational faults
Automatic closing or opening does not operate
If the battery of the car has been disconnected and then reconnected, the automatic closing and opening function does not operate. The system must be activated. Proceed as follows in order to re-establish the function:
• turn the key in the lock of the driver door into the closing position and hold it there until all of the windows are closed,
• release the key,
• once again insert the key and turn it into the closing position for about 3 seconds.
The PDF manual states:
Operational faults
Electrically operated power windows do not operate
If the battery of the car has been disconnected and then reconnected, the electrically operated power windows do not operate. The system must be activated. Proceed as follows in order to re-establish the function:
• release the key,
• Once again insert the key and turn it into the closing position for about 3 seconds.
So this suggests that at some time during the 2 year interval the electronics were changes so that on later cars the windows don't operate at all? Why otherwise would they change the text I wonder?
Link to comment
For people having intermittent problems try taking out all the relevant fuses, cleaning them, then ensuring they're fully and properly inserted. Mine turned out to be a loose dirty fuse...
Link to comment
  • 10 months later...
  • 11 months later...
  • 1 year later...
Thanks. Worked perfect for me, skoda fabia 1.4 8v petrol 2003...I knew they was working when I test drove the car! Bought it, got back home, put a new battery on it, and the 1 touch stopped, scratched my head for a week, blaming the car dealer etc etc, found this post, done the key thing and they started working, I was amazed!
Now I just got to watch the wife doesn't break the passenger window switch totally, by keep playing with it LOL
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
