Today I set about replacing the Engine Oil and Filter on my vRS. This is how I did it - Parts Required - Oil Filter p/n 071115562A = �5.52 Sump Plug p/n N90813201 = �0.96 5 Litres Millers XFE-PD = �21.99 Tools Required - T25 Torx Screwdriver. 19mm Socket for sump plug. 32 or 36mm Socket for oil filter housing (depending on model) Washing up bowl (tell the missus first). (I highly recommend either a 32 or 36mm Impact Socket, about �6 from your friendly local motor accessory shop. As
