Pikaa
Finding my way
Everything posted by Pikaa
  1. Hi! For the Skoda Octavia 3 (2013-2017) and even the facelift (2017-2019) version, which is currently the most proven gasoline engine that you would like to buy? I don't mind if I make a few arguments. Thanks!
  2. basically, to remedy the oil consumption, would only engine disassembly help?
  3. Can it be deposited in a particle filter? or egr valve?
  4. So that's not bad yet? don't worry Where can this oil go then, won't it ruin something?
  5. Hello, Is it natural for a car with 190,000 km to consume ~ 3,000 km/0.5 L of oil? Or is there a problem with this engine type? No smoke, no leaks anywhere! There was also an oil change, control, valve cover and oil filter housing replacement. Do you have any ideas, or should I get rid of the car now? Skoda Octavia 3, 2014, 2.0 diesel, CKFC.
  6. Thank you for your answer! Yes, I know mine doesn't support it, I just thought this tool would replace it.
  7. Hi! I saw the following carplay adapter on a website. If I have a MIB1 player in my car, but it does not have mirrorlink or an Android car, how can it work with this adapter? Could you help me so that I don't buy it? Thank you!🙏
  8. What is this gurgling sound? Most of the time, it fishes well on the first launch. Meanwhile, the coolant is missing from the tank. Skoda Octavia 3, 2014, 2.0TDI, CKFC
  9. I have driven the car 4300 km since the last oil change. 184.000 km.
  10. Skoda Octavia 3, 2014, 2.0TDI (CKFC) My problem is the following, I'll try to describe it briefly: I bought the car from Germany in October. The basic things were replaced, filters and oils (CASTROL 5W30, the last owner also used this). Everything was fine for a while when the water in the expansion tank started to run out. Because of this, the oil filter housing was replaced and the water did not drain afterwards, so this problem was solved. Now, however, the water is not running out, but the oil is running out. It doesn't smoke, there is no oil on the belly shield, it has power and there are no error codes! approx. 2000km 0.5L oil. Do you have any ideas on what makes you consume so much oil?
