slicendice
Everything posted by slicendice
  1. At the risk of tempting fate, I've thus far been fairly lucky when it comes to suffering break-ins, thefts, etc. But it feels like reports of thefts and suchlike around where I live are increasing; every other day there's been some kind of break-in...some at night, some in the middle of the day, some where intruders have brazenly taken a series of running jumps at a door until it breaks. Now I know that no home security system is 100% guaranteed to prevent such things happening, but from what I've read, they can help to lessen the likelihood of becoming a victim. I do have an alarm fitted at the moment (was installed when house was re-wired 5 years or so ago), but it only covers some of the house (downstairs) and tbh it rarely gets used any more as it kept going off at random times for no obvious reason (and didn't appear to be caused by spiders as the sensors were regularly cleaned). So I'm thinking about getting something a bit more useful. I do appreciate that just having the alarm box on the outside of the house can, apparently, act as a deterrent, but it would make sense to go beyond that for those times when it doesn't act as a full deterrent. So I've started to delve into the world of alarm systems and surveillance cams...and what a vast world it is! But then I suppose that goes for most things tech-related. At the moment, what I'm wondering is: what sort of alarm system is best - wired or wireless? Appreciate one of the biggest differences is probably ease of installation, but that aside, is one notably better than the other? is it worth getting door sensors that get triggered when the door opens? Or would the IR room sensors make them a bit redundant? are outdoor surveillance cameras worth it? if they are worth it, is it better to have two independent systems (i.e. an intruder alarm and then a separate surveillance cam system) or one integrated system? Appreciate that having one system may be easier to use due to the very fact it's integrated, but it seems the options are much more limited if you go that route (i.e. not as many packages that include alarm and cameras) - and if you mix 'n match two independent systems, you can probably get something more comprehensive/suitable. If anyone can help with the above, or has any recommendations or info on their own system, I'd be very grateful.
  2. I have a ream dash cam that I want to try and fit so I need to figure out how to remove the trim around the rear screen. I was hoping to find a YouTube vid of someone doing just that so I could see exactly how to do it, but as of yet I've not managed to find one. From poking around on here and online, it sounds as though it's held in place by spring clips around the edges, as indicated below...is that right? Are there any other clips or screws that need removing? And to remove the clips, is it just a case of swinging on them hard enough to spring them out? Any particular order?
  3. Thanks Langers...I did originally try this but it seems to only be an option if you have a Google account. If you don't, then you can't open the doc. I tried sharing the link with a test user (that has no Google account) and following the link just takes you to the Google login screen. I know that quite a number of the people who need to access this don't have a Google account so it's not a solution that would work in this instance.
  4. I have some data in a Google sheet that needs to be accessed by quite a number of people so I need to make it available to them online. I know this is dead easy in terms of sharing a link, but the data contains names and addresses so has to be treated in accordance with GDPR. Consequently I can't just pass out the link to the Google sheet, as anyone who happened to get the link would then be able to view it. I initially thought I'd just be able to add a password to the Google sheet but it appears (somewhat surprisingly) that it's not possible to do this. The only thing that it seems you can do is control which cells within the sheet are editable. So I'm looking at ways of making this available online but behind some kind of password protection. It would need to be kept up to date from the Google sheet (i.e. changes to data in the sheet would be visible). I know it's possible to render a Google sheet as HTML fairly easily, but from what I've seen that would require a link to the Google sheet to be embedded in the HTML, so anyone with half an ounce of know-how would be able to extract it and then access the sheet directly. I'm just wondering if anyone has done anything like this before? Or could give any pointers on the easiest way to achieve this? I've been having a nose around Google Web Apps scripts but I don't know if that's the best option or whether there might be an easier way to do this? Thanks
  5. Thanks for the info The version info for mine is: 5L0051236T 0820 ECE1 2017/18 SHIELD: SHIELD 2016-44 (build 309) I've updated with the MIB2 files and appears to be working fine. I've got a backup of original files and I know the MIB2 works, so when I get a min I'll try the VW link above and see if that works too. Thanks again
  6. Sorry if this is kinda obvious, but I'm new to the Amundsen update process. I have a '67 Octavia with MIB2 (at least, I'm assuming that's what it is!) and looking to update the maps. I've been to the updateportal.skoda-auto.com site and downloaded the latest ECE1 file, but noticed it was last updated in 2019...so in hunting down if there's a newer version I came across this thread. Am I right in thinking that the VW links at the start of this thread should work if downloaded and used in the same way as the Skoda ones?
