Auto Adjusting Head Lights
Hi
Can someone help me ,when starting the car and turning the head ligth on ,the O/S head light move up and down but the N/S does not move.Is this ok or have I got a problem with the N/S light auto adjuster.
Mark :confused:
Both should auto adjust at the same time (Xenon's)
so i would get it checked / replaced under warranty
As suggested above you have a problem with your headlamp adjustment or possibly the sensors on the axle...........
ok Lads
where is the sensor on the axle?
Also if I remove three bolt that hold the head light in place can I remove the head light without having to removing the bumper.
Many thanks
ok Lads
Many thanks
You'll notice the sensors near the shocks after you remove the tires. Sensors are linked between the chassis and McPherson-thingeys so they'll get the needed position data that way.
Unfortunately you need to remove the bumber for a complete removal of headlight. There are 2 more bolts under the headlight which can be accessed only after the removal.
As said above, bumper has to come off to allow access to two other mounting bolts.........search this forum for 'bumper removal' as I have posted up a thread about it explaining how to do this before..........:thumbup:
