When i lock my car with remote key flasher do not work!??
Hello, my english is bad becaouse but i hope that you will relaize what i want to say.
When i lock the dor with my remote key the flasher's on the car do not want blink. What can be a problem?
Edited by Zoki81
Little offtopic...
Is it possible to get it so that blinkers doesn't blink when car is locked?
Or is it possible to change how many times blinkers flash?
Not 100% sure on the Superb, but you can enable / disable the flash with Vag-Com on the Roomster / Octavia / Fabia. I don't see why it can't be coded on the Superb if you had someone in your area with Vag-Com
Ok i will take skoda to diagnostic in servis , maybe that help!
I had a similar problem with my Superb and it' was related to a water ingress problem around the pollen filter housing which unfortunately corroded part of the cars main wiring loom which runs under the passenger seat. This topic is extensively covered on Briskoda with plenty of useful tips on getting it sorted.
do you have some pictures what i must to do to fix a problem? thank you
If you mean the pollen filter problem, I've got pics on my project diary.
  • 4 weeks later...
You may well find that the conveniance control module is seeing a door, boot or bonnet open. I'd check the bonnet switch first.
If the ccm doesn't see all doors etc closed it won't set the alarm in the first place. You'll probably find that the door LEDs arn't flashing either ?
HTH
HTH
No, that all work well. Alarm turn on when i lock the door with key, but car do not flash.....
How can i alone fix a problem?
  • 4 weeks later...
Can VAG turn off this? Maybe there is problem!
  • 3 months later...
can you detail explame this problem?
Are your hazzard and indicators still working ok under normal conditions?
Yes they work ok, i do not know is wire for this under carpet on left side of car? Maybe wire is corrode, but i do not know what wire is it to look it :(
In your case I think it'll be under the drivers seat.
This might be what it looks like
http://cgi.ebay.co.uk/Genuine-VW-Caddy-Golf-Jetta-Central-Control-Unit-NEW_W0QQitemZ400051834937QQcmdZViewItemQQimsxZ20090525?IMSfp=TL0905251410004r11202
From what I can find it would seem that it's under the seat and carpet on the NS of the car, I would push the seat forward and look under where the air vent on the floor is, I believe you need to lift the carpet and some say the seat needs removing as well, where I think it is is the only logical place I can think it would be because it has the lifted profile from the floor.
One other thing, a mate of mine had an indicator stalk fail on his car, not sure if he had the same fault as you though, I'll ask when I see him.
Edited by Supurbia
Check all your doors, bonnet and boot are fully closed.
Yes i check it, it is not problem because alarm work ok!
The indicators not working mean either a lock cant engage, or cant deadlock.
