Hint: HTC TyTN2 and GSM3 Bluetooth
Hi all, just had funnies with my HTC TyTN 2 (WM6.1), I did have it working ok, then it would'nt connect. Found if I go into the bluetooth settings and click ok, it works again, until it reboots. Then doing the "ok" sorts it out.
My phone does a backup on a monday evening, hence why it played up today, the other day also had issues, due to the battery going flat causing it to forget the rSAP setting again. Even if the rSAP is ticked, it might not be on!
Cheers all.
