Are the Reverse Sensors of the orig. Skoda aftermarket Kit identical to the factory fitted ones?
Hi,
two of my Parking Sensors gave up a while ago and I didn't get it fixed, as I didn't think it was worth £200.
But recently I found someone on Ebay who was selling a complete & original Skoda aftermarket reverse sensor kit, and decided to take a risk. I won the Item for £37. The Item Number is BEA 500 001.
Does anyone know if I the Sensors will fit just fine and can be exchanged easily with the defect ones, or if any modifications are necessary?
If they fit just fine I will put 1 of the sensors back on Ebay to get my money back, as I saw someone selling a single Sensor for alomst £40 last week, and keep the rest of the Set as spares. :rofl:
Cheers,
dsab
Edited by dsab
Have the same problem of faulty sensors and saw the same kit and nearly bid on it too but when I viewed the enlarged photos saw the part numbers were different so decided to give it a miss. The correct sensor part numbered are 3U0 919 275 suffixed either by A or B. Hope they do work for you, only way to find out is to plug one in to try it I guess.
Good luck
Good luck
I couldn't read any part numbers from the pictures. I only know that the Set has the product code BEA 500 001. I guess I will have to wait and see...
If they don't look identical they will just be put back on Ebay. Can't loose a lot on it, I guess.
hahah i also bidded on these.!! i couldn't really make out he shape of the actual sensor. i think the part number quoted is for the whole kit, rather than the individual sensors..
i have however won a bid on some porsche sensors.. which apparently are the same, and are only £30 as opposed to £85 from the stealer...
will let you know if they fit...
  • 3 months later...
Sorry for the late reply. Anyway, had the same problem, so the guys in Skoda service offered me original sensor 70 eur per piece (and I've had 3 dead) or a "after-market" (chinese :) ) set for 90 eur. And so far (2 years already) works ok. And also, I have now a display warnign also, with the sound :)
br
