Winter Tyres
At present I am running my car on 225/45/17 and was thinking of changing down to 16" rims and getting winter tyres, as I can pick up a set of 4 new steel rims at a very good price. My question is, what size tyres should I go for, on these rims, to keep speedo as accurate as possible?, should they also be 225/45, but on 16"s, or something different.
Thanks for any help you may be able to offer.
205 55 16's are what you need :thumbup:
Keep in mind that you need extra load tyres-
Can't remember if they are 91 or 94 load index (im on my netbook so I don't have the info to hand)
94 load index
205/55R16 tyres seem to be available with either a 91 or a 94 Load Index, similarly 225/45R17.
Check the VIN plate to confirm the maximum axle weight requirement and hence the minimum Load Index requirement.
91 corresponds to a maximum axle weight of 1230 kg, or 1118 kg if you want to include an extra 10% margin.
94 corresponds to a maximum axle weight of 1340 kg, or 1218 kg with the extra 10% margin.
On the VIN plate, the front axle is axle 1.
Edited by AnotherGareth
