Polybushes
Im trying to work out which ones i need to order ive found these on ebay
ebay
are these for the vrs ? or are the bushes the same across the range ? also what size rear ones do i need it states 3 different sizes
cheers in advance
I've just got a free set of superpro anti lift bushes, rear beam bushes, wishbone ones and arb bushes.
Shame I can use them yet
no need to rub it in :dull: i never get any thing free in the next few days i will be spending around 1k on parts for my vrs
intresting reading any idea what size i need for my car ?
Of hand ..no.....just get an adjustable spanner or dif sizes or spannners to slide over the ARB...the one that just fits is the dia! B)
On a lot of the adverts it says the bushes are suitable for 00-05 cars. Does that mean there where revisions to the suspension layout after 05 or are the adverts just out of date?
Thanks.
Harry.
Look at my post:
http://briskoda.net/forums/topic/200949-upgrade-the-bushes/
Although I have all Powerflex (execpt engine mount)....I would not get all Powerflex again!! I Think that some of the Superpro ones are better designed......read my post before you buy!!! B)
What's wrong with Powerlfex? Your post, doesn't state the issue, rather it explains the designs of others?
Also, what's the udder mod? Briskoda's search is crap, and not much help....
Superpro is defo superior
Why?
Compounds are different and superpro don't change over time. I've had powerflex on the front wishbones and they are knocking.
Actually the udder mod is rubbish
That was Powerflex`s way of doing the job
but to be fair , they have changed the design of them , and have got a replacement full bush now
That had just come out as I left the tuning game
But as has been said , I had better luck with the Superpro range
This is because thier range differs between petrol and diesel engines
The diesel engines with Powerflex , can cause more vibration
I know one guy fitted a Powerflex bush to his Octy diesel , and his Mrs threattened to divorce him if he did not get t changed back
So it does make a difference
I must also admit , that I had all my Superpro bushes fitted as a tester for them
They are good , and if I had to put money on another set of bushes , then that is where they would go
My Fabia NEVER had the rear beam bushes changed either
So to be fair , is it worth buying a kit at that price if it is not required
The Cupra bush for me , is a good choice , but hey , if you are doing the rest in Superpr , or Powerflex , may be worth just doing the whole front end in them
Superpro for me too ;)
Sarah
Please read my post again as I explain the designs of all of the bushes.....I do state that the front bush on the front wishbone "eats" the subframe....I also state that the rear beam axle bush needs a puller for it!! These are the two that I would not get by Powerflex!! B)
I did have the "udder" or "table" insert by Powerflex for the front console....I threaded the hole in the end of the hex rod on the wishbone and used an M12 stainless bolt and stainless repair washer...this combo held the insert on much better....actually held the OEM bush in place when one of the "web flanges" wore out!!! Now have their new two part console bush as can be fitted insitu (didn't want to remove the console)!! All of my bushes are Powerflex bar the engine mount (SuperPro)......but if I had time I would swap the two at the top of this post for SuperPro as better!!! B)
P.s......Powerflex, Whiteline, and SuperPro console bushes work in a much better way that the "Cupra" bush!!! (console unit)
Edited by fabdavrav
